SecurityUtils.getUsername() does not support Spring Jwt principals monitor extension
With GeoServer 3.0.1 using the official OIDC extension and Microsoft Entra ID authentication, Monitor audit logs contain:
org.springframework.security.oauth2.jwt.Jwt@792fca0a
Checking the repo:
MonitorFilter
→ SecurityUtils.getUsername(auth.getPrincipal()) and SecurityUtils.getUsername() falls back to principal.toString() for principals that are not
UserDetails
Principal
org.springframework.security.oauth2.jwt.Jwt is neither of those types, resulting in the object reference being written to audit logs.
Issue found with help off AI. Possible fixes (also with AI as I can not code nor really understand this, but it might help to fix this)
Possible Fix
Instead of extracting the username directly from the principal object, use the authenticated Spring Security identity:
Authentication auth = SecurityContextHolder.getContext().getAuthentication();
String username = auth.getName();
This is generally more robust and avoids assumptions about the principal implementation class. It should work consistently across:
•UserDetails
•OIDC
•OAuth2
•JWT
•future authentication providers
Thanks for further investigating/solving this
Here are instructions to get any code change happen in GeoServer:
@TVA did you made a pull request for this? If yes, could you send me the link? Otherwise I will make the pull reguest regarding my ticket.
@mvoermans no i did not because i cant make a jira ticket and to be honest i have no clue about software dev.
So fell free to go ahead with your ticket and PR
I created a pull request: Monitoring records the Jwt object instead of the user name for bearer token requests by mvoermans · Pull Request #10140 · geoserver/geoserver · GitHub
