Slide.show.sh update
Hi, all.
Last week, I was having a problem with slide.show.sh. I thought it was a
problem caused by the grass5 changeover, and a script that had not been
updated. I was wrong.
slide.show.sh takes the list of mapsets to show slides from from the
search path. If there is no search path, it takes the list from the
PERMANENT mapset. I rarely set a search path with what I am doing, so the
script is defaulting to PERMANENT. With what I am doing right now, I have
no maps in PERMANENT. So, slide.show.sh failed to show anything.
What slide.show.sh should do is default to the current mapset, as well as
the PERMANENT mapset (at least in my humble opinion). So, I propose the
following change on line 82 of slide.show.sh (as shown by a
"diff new old") :
82c82
< MAPSETS=`echo $MAPSET PERMANENT `
              MAPSETS=PERMANENT
Below is a complete script. This change should allow those of us who do
multiple small, short-term analyses to use slide.show.sh.
Enjoy,
Angus Carr.
if [ $? != 0 ]
then
  exit 1
fi
d.colormode fixed
# set gis variables
eval `g.gisenv`
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
# set defaults
DOWN=3
ACROSS=4
# evaluate arguments
for i do
  case $i in
    down=*)
      DOWN=`echo $i | sed s/down=//` ;;
    height=*)
      DOWN=`echo $i | sed s/height=//` ;;
    across=*)
      ACROSS=`echo $i | sed s/across=//` ;;
    width=*)
      ACROSS=`echo $i | sed s/width=//` ;;
    mapsets=*)
      MAPSETS=`echo $i | sed s/mapsets=//` ;;
    mapset=*)
      MAPSETS=`echo $i | sed s/mapset=//` ;;
      echo ""
      echo "Unrecognized option: $i"
      echo Options: across=#maps_across down=#_maps_down
      echo Defaults:
      echo " across = $ACROSS"
      echo " down = $DOWN"
      exit
  esac
done
d.frame -e
# figure height and widths of the windows
avail_width=`expr 99 - $ACROSS`
avail_height=`expr 99 - $DOWN`
map_width=`expr $avail_width / $ACROSS`
wind_height=`expr $avail_height / $DOWN`
label_height=`expr $wind_height / 10`
map_height=`expr $wind_height - $label_height`
# generate the needed windows
at_horiz=0
left=1
while [ $at_horiz -lt $ACROSS ]
do
  at_vert=0
  top=99
  right=`expr $left + $map_width`
  while [ $at_vert -lt $DOWN ]
  do
    bottom=`expr $top - $map_height`
    d.frame -c map.$at_horiz.$at_vert
at=$bottom,$top,$left,$right
    top=$bottom
    bottom=`expr $top - $label_height`
    d.frame -c lab.$at_horiz.$at_vert
    at_vert=`expr $at_vert + 1`
    top=`expr $bottom - 1`
  done
  at_horiz=`expr $at_horiz + 1`
  left=`expr $right + 1`
done
# Get list of current mapsets
if [ x$MAPSETS = x ]
then
  if [ -r $LOCATION/SEARCH_PATH ]
  then
    MAPSETS=`cat $LOCATION/SEARCH_PATH`
  else
  fi
fi
# Draw the maps
atnum=0
totmaps=`expr $ACROSS \* $DOWN`
for mapset in $MAPSETS
do
  cd $LOCATION/../$mapset
  if [ ! -d cell ]
  then
    continue
  fi
  for i in MASK `ls cell`
  do
    if [ ! $i = "MASK" ]
    then
      atnum=`expr $atnum % $totmaps`
      at_vert=`expr $atnum % $DOWN`
      at_hori=`expr $atnum / $DOWN`
      d.frame -s lab.$at_hori.$at_vert
      d.erase
      echo $i in $mapset | d.text size=80
      d.frame -s map.$at_hori.$at_vert
      d.erase
      d.rast $i
      atnum=`expr $atnum + 1`
    fi
  done
done
