I would like to report into https://osgeo-org.atlassian.net the issue so at least the documentation could be improved, but with my account I can’t do it
a) Thank you for documenting your fix. Could you be so kind as to edit the documentation itself (requires a GitHub account and following Quickfix - Documentation) and add it there for everyone? This issue might also be relevant: 2.27.1 New data source page not working
HI @Peter I stumbed again with the jira issue, my email there is sacco2 at hotmail.com, and I can’t create any issue (but I can view them)
The issue I wanted to report is that with the current WPS plugin there’s a dependency on arcgis that’s missing
GeoServer 3.0.2 on Tomcat 11. After installing geoserver-3.0.2-wps-plugin.zip (and wps-download), GeoServer fails at startup:
BeanCreationException: Error creating bean with name ‘arcGridPPIO’: Lookup method resolution failed
Caused by: java.lang.NoClassDefFoundError: org/geotools/gce/arcgrid/ArcGridReader
Since ArcGrid was moved out of core into its own extension in 3.x, the WPS plugin (ArcGridPPIO) now has an undeclared dependency on it. Installing geoserver-3.0.2-arcgrid-plugin.zip fixes it.
