Status of build.geoserver.org ?
Trying to download community plugins but the build server doesnt answer.
Sometimes it works briefly, but then it dies. Tried today, one week ago and several weeks ago…
Tried several computers and networks with 0 positive results. Cant find any mirrors either.
Any ideas?
Seems to work fine for me from the UK, you don’t say which country you are in, or if your internet connection? has problems with anything else?
Ian
From sweden, and I have no other connection issues.
And…. It started working after this post here was accepted :slight_smile:
Lets see if it holds.
Best regards,
Jesper
Hi @jesade-vbg welcome to the GeoServer community!
I also occasionally run into trouble with the build server, making too many authentication attempts in a row, and then I get my IP address blocked for a period of time.
Is there a chance some script at your IP address is making invalid attempts and getting your IP address blocked?
The official downloads are on Source Forge, but it seems you are looking for a community module. You have the option (recommendation even) of downloading the source code and building these. In each case the community modules is looking for more resources to be completed; so setting up a mirror is not really ideal.
Thanx, interresting. Curious to know how browsing to the site is an invalid attempt :slight_smile: (Yes I also scripted downloads). But anyways, right know its working.
I know I can build but its takes a while and kind of slows down my fast docker setup so “ready to go“ zip-files are preferred.
Thanx again!
Browsing the site is not considered harmful, but requests ending in a 404 (not found) or a security error are considered as part of a brute force attack if they accumulate a bit
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Il gio 6 nov 2025, 08:49 Jesper A via OSGeo Discourse <noreply@discourse.osgeo.org> ha scritto:
jesade-vbg
November 6
Thanx, interresting. Curious to know how browsing to the site is an invalid attempt :slight_smile:(Yes I also scripted downloads). But anyways, right know its working.
Thanx again!
Visit Topic or reply to this email to respond.
You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here.
