surface_deviations
Helena wrote:
If you use the new s.surf.tps which Irina has just put
on moon for creating a raster file you can use the option to
output deviation site file which is computed simlutaneously
with the somputation of the resulting raster map.
Where is this new s.surf.tps? I looked on /incoming on moon.
Is it a different name?
Thanks
Kym M. Lenkus
Davidson Laboratory
In info.grass.user you write:
Thanks
Kym M. Lenkus
Davidson Laboratory
You have to get the whole interpolation library, uncompress it and unpack it.
It is called interp_lib.shar.Z
Irina
