Swmts-multi-dimensional-plugin: Is it possible to suppress the error message in the GeoServer if there are no objects in the requested time period?
I have a layer in GeoServer configured like this:
Is it possible to suppress the error message in the GeoServer if there are no objects in the requested time period and just return an empty map image instead?
Could not find a match for ‘time’ value: ‘2024-07-07T11:16:02.404Z/2024-09-06T10:02:20.513Z’
So far I was not able to find a setting for this.
You have the “presentation” set as List, which requires an exact value. Providing exact time values is kind of hard! What with timezones and all …
You may wish to consider one of the other continuous options? I expect that when combined with nearest match you will get a result (if not the empty map you prefer).
You may have a new feature request - something like: “nearest” but resulting in an empty map…
