This topic needs a title
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: digitizing problems - request for advice
Message-ID: <C2543A.7MD@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <01GTZEUVA9WY006ANO@GW.AGR.CA>
Date: Mon, 8 Feb 1993 17:18:46 GMT
Lines: 48
In <01GTZEUVA9WY006ANO@GW.AGR.CA> JOHNSON@abrsle.agr.ca (Dan Johnson, 1-403 327-4561) writes:
Dear Sir/Madam at GRASS HQ:
We are having an unusual problem with GRASS 4.0 and we wonder if it has
been noticed by other users. Calibration of the digitizer indicates that
squares on graph paper come out like rectangles, but not always the same
side length, and this only seems to happen below a side of 3 cm on the table!
Dave Satnick in Ellensberg helped us out a bit, and thought that that the
problem must lie with the digitizer (Altek Model AC30, table HS-243, Gentian
Electronics), and the digitizer people naturally say that the problem lies
with GRASS. It may well be the table, but we wonder if there have been
any similar experiences?
- Anne Smith; Dan Johnson
smitha@abrsle.agr.ca
johnson@abrsle.agr.ca
Research Station
P.O. Box 3000 Main
Lethbridge, AB Canada T1J 4B1
phone (403) 327-4561, ext. 301
facs. (403) 382-3156
The software in the GRASS digitizer program which converts digitizer
coordinates to map coordinates is an affine transformation.
  east = Ax + By + C
  north = Dx + Ey + F
This is a linear transformation that allows the map to be scaled,
translated, and rotated. The scaling also allows the x scaling to be
different than the y. Linear regression is used to determine the
A,B,C,D,E,F based on the registration points.
The transformation described here is one that the affine transformation
can't do - ie, apply different scales to different parts of the map.
If the coordinate grid on the map is square then the problem may lie
with either the digitizer or the registration points (or perhaps the
map has shrunk).
Michael Shapiro U.S. Army CERL
Environmental Division
