I need some help;
I am trying to compile xgrass on a SPARC IPC SUN OS 4.1.1 with
with Motif GUI toolkit from ICS. I run Setup in the configure
directory and everything seems to work OK. When I run "make World"
It runs to the point of compiling Pixel.c and then I get the following...
cc -O -DSVR4 -DSYSV -D_NO_PROTO -DUSE_GRASS -lnsl /usr/ucblib/libucb.a -I. -I/cgis/grass4.1/src/include -target sun4 -c Pixel.c
"Pixel.c", line 148: warning: undeclared initializer name XtCopyFromParent
"Pixel.c", line 148: illegal initialization
*** Error code 1
make: Fatal error: Command failed for target `Pixel.o'
Current working directory /cgis/xgrass/src/lib
*** Error code 1
make: Fatal error: Command failed for target `all'
*** Error code 1
make: Fatal error: Command failed for target `World'
Before I start diging I wonder if someone has any suggestions.
Thanks
Marty Holko
a16holko@attmail
