Following the SPF change (which should now be already propagated),
I suggest we deploy the mail-servers playbook to production,
which would have the effect of updating the configurations on the osgeo9-mail container
to use the production URLs ( mail.osgeo.org and lists.osgeo.org ) instead of the staging ones.
What do you think ?
This is how you can see what would change:
ANSIBLE_CONFIG=ansible.osgeo.prod.cfg \
ansible-playbook -v deployment/deploy-mail-servers.yml
-l osgeo9_mail \
--check --diff
Most notable changes are:
TASK [list-server : Install /etc/mailman/mm_cfg.py] ****
--- before: /etc/mailman/mm_cfg.py
+++ after: ...
-DEFAULT_EMAIL_HOST = 'lists.staging.osgeo.org'
+DEFAULT_EMAIL_HOST = 'lists.osgeo.org'
-DEFAULT_URL_HOST = 'lists.staging.osgeo.org'
+DEFAULT_URL_HOST = 'lists.osgeo.org'
TASK [mail-server : Install postfix main.cf configuration] *****
--- before: /etc/postfix/main.cf
+++ after: ...
-myhostname = lists.staging.osgeo.org
+myhostname = lists.osgeo.org
-myorigin = mail2.osgeo.osuosl.org
+myorigin = osgeo.org
-smtpd_tls_cert_file = /etc/letsencrypt/live/lists.staging.osgeo.org/fullchain.pem
-smtpd_tls_CAfile = /etc/letsencrypt/live/lists.staging.osgeo.org/fullchain.pem
-smtpd_tls_key_file = /etc/letsencrypt/live/lists.staging.osgeo.org/privkey.pem
+smtpd_tls_cert_file = /etc/letsencrypt/live/lists.osgeo.org/fullchain.pem
+smtpd_tls_CAfile = /etc/letsencrypt/live/lists.osgeo.org/fullchain.pem
+smtpd_tls_key_file = /etc/letsencrypt/live/lists.osgeo.org/privkey.pem
-mydomain = staging.osgeo.org
+mydomain = osgeo.org
--strk;
Libre GIS consultant/developer ![]()
strk's services
