Does anyone know how to change the background and font color of the tooltip boxes in LizmapWebClient? I think I found it by chance in the Lizmap folder on the server a few weeks ago and changed it, but I can’t remember where.
The current problem is that in some of my QGIS projects, the font appears black against a dark gray background, and the font is also Times-like rather than sans serif.
Can you provide a screenshot, just to make sure that i understand what you mean with tooltip box? ![]()
Edit: Oh, an please refrain from double-posting in the englisch AND german forum, let’s try to keep the forum neat & clean ![]()
Fiddling a bit around with the html, here is some example code which should do what you need:
<style>
.lizmapPopupTable {
background-color: rgba(255, 255, 255, 0.7) !important;
color: black !important;
.lizmapPopupTable th,
.lizmapPopupTable td {
</style>
<table class="table table-condensed table-striped table-bordered lizmapPopupTable">
<thead>
<tr>
<th>Field</th>
<th>Value</th>
</tr>
</thead>
<tbody>
<tr>
<th>id</th>
<td>[% "id" %]</td>
</tr>
<tr>
<th>flaeche</th>
<td>[% "flaeche" %]</td>
</tr>
<tr>
<th>bezeichn</th>
<td>[% "bezeichn" %]</td>
</tr>
<tr>
<th>bemerkung</th>
<td>[% "bemerkung" %]</td>
</tr>
<tr>
<th>nr</th>
<td>[% "nr" %]</td>
</tr>
<tr>
<th>planung</th>
<td>[% "planung" %]</td>
</tr>
<tr>
<th>datumwandl</th>
<td>[% "datumwandl" %]</td>
</tr>
<tr>
<th>standalt</th>
<td>[% "standalt" %]</td>
</tr>
<tr>
<th>flächengr</th>
<td>[% "flächengr" %]</td>
</tr>
<tr>
<th>flächen_1</th>
<td>[% "flächen_1" %]</td>
</tr>
</tbody>
</table>
change the color from black to anything you like. This is how it looks now with the example code:
Add the code in the Plugin for the Tooltip HTML Template. Click on the <> to see the pure code:
Thank you very much for your support! Especially the <>Button revealed a mystery - some unwanted code had crept in and caused the bad design. After deleting it, everything looked fine, but it happened a second time later. I could not find out so far which particular action is the trigger.
