On Wed, 20 Jan 1999, Alan Eugene Davis wrote:
Long ago, I installed the spearfish tutorial data set. Now I have
upgraded to 4.2.1, this data set is working. I haven't been able to use
the imagery or global data sets. When I try to specifiy anything, in
the opening screen (asking for mapset etc.) I always get the message
that I do not have permission to access the mapset.
I changed the ownership and permissions, without success.
I've got the spearfish database in /wrk/tests/grass/sp/spearfish. Consider
the following to access it.
# Some commands to get spearfish working
cd /wrk/tests/grass/sp
# Enter the following data on the initial screen
GRASS 4.2.1
LOCATION: This is the name of an available geographic location. -spearfish-
is the sample data base for which all tutorials are written.
MAPSET: Every GRASS session runs under the name of a MAPSET. Associated
with each MAPSET is a rectangular COORDINATE REGION and a list
of any new maps created.
DATABASE: This is the unix directory containing the geographic databases
The REGION defaults to the entire area of the chosen LOCATION.
You may change it later with the command: g.region
LOCATION: spearfish_____ (enter list for a list of locations)
MAPSET: ferenc________ (or mapsets within a location)
DATABASE: /wrk/tests/grass/sp_______________________________
AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
(OR <Ctrl-C> TO CANCEL)
# then set the default region
GRASS-GRID > g.region -d
# open graphics monitor
GRASS-GRID > d.mon start=x1
Graphics driver [x1] started
Mapset <ferenc> in Location <spearfish>
# display elevation data in raster format
GRASS-GRID > d.rast elevation.dem
Good luck,
MF
.... http://www.relief.hu/ .................................................
phone/fax: +36-88-272644 | Microsoft is not the answer.
cellular: +36-20-9576742 | Microsoft is the question, and the answer is no.
