Unable to overwrite validated records
I’m using GeoNetwork 4.2.6 and have run into an issue when overwriting records that have already been validated. The overwrite operation runs without errors, but the existing metadata does not get updated as expected.
Is this the intended behavior (GeoNetwork blocking updates to previously validated records), or is it more likely a transaction handling issue?
Has anyone else experienced this problem, and if so, how did you resolve it?
Thanks in advance for your insights
