Hello,
I just joined and posted about containerized qgis. I am unable to reply to my own post; must be an issue with permissions.
Thanks!
Strange what error did you get or message did you see?
Thanks, the post was closed, for some reason. Now I can’t even see it.
No problem as I solved this issue : I was generating .qgs project locally and then using it with qgis server but the host name in the project xml had to be changed to postgis, which is what the qgis server uses to connect to postgis container.
