Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: <grassu-list@max.cecer.army.mil>
Cc:
Subject: Undeliverable Message
Message not delivered to recipients below. Press F1 for help with VNM
error codes.
VNM3043: MR MARK ADAMS@TEC@FLW DCD
VNM3043 -- MAILBOX IS FULL
The message cannot be delivered because the
recipient's mailbox contains the maximum number of
messages, as set by the system administrator. The
recipient must delete some messages before any
other messages can be delivered.
The maximum message limit for a user's mailbox is
10,000. The default message limit is 1000 messages.
Administrators can set message limits using the
Mailbox Settings function available in the
Manage User menu (MUSER).
When a user's mailbox reaches the limit, the
user must delete some of the messages before
the mailbox can accept any more incoming messages.
---------------------- Original Message Follows ----------------------Sender:
Precedence: Bulk
Precedence: Bulk
Cc:
error codes.
Precedence: Bulk
Precedence: Bulk
Precedence: Bulk
Cc:
Subject: Re: different locations
error codes.
---------------------- Original Message Follows ----------------------On Wed,
7 Feb 1996 sw@kreutler.de wrote:
Hi all!
I want to know, if it is possible to use GRASS with maps stored at different
locations.
because in the file .grassrc there is only one possible line for LOCATION.
different locations can be different machines in the net to.if this is possible, please tell me how to use .grassrc
hints are welcome too!thanx in advance
Stephan
GRASS will only look to mapsets within your current location and GDBASE.
But - if you really want to look at maps stored elsewhere you can use
symbolic links and nfs mounting to create mapsets in your location that
are stored elsewhere. Just be careful that the coordinate, zone and
other infomraiton are consistent. If you are using a UTM zone location,
and have a mapset that is linked to data stored in latlon you will have a
mess.
Susan Huse /\ http://www.regis.berkeley.edu/sue
REGIS / \ / \/ \ /\ sue@regis.berkeley.edu
University of California / / \ (510) 643-6307
Berkeley \ / \
