I have posted this question in GIS.StackExchange but without a reply, I hope I can get more luck here since it is a GeoServer dedicated forum.
I am trying to upload a layer using the GeoServer (2.28) REST API using the Importer extension (using python). I do not know what I am doing wrong.If I use the PUT method when the sld does not exists in an empty workspace, it will load the layer and sld but will not apply the styling. If I reload a second time using the POST method for the same layer and sld in the same workspace the style is applied correctly. below are the code I am using, but I cannot figure out what I am doing wrong:
1.1 To upload a layer - (workspace is empty):
# Step 1: Create import job
POST /rest/imports
"import": {
"targetWorkspace": {
"workspace": {
"name": "city"
# Step 2: Upload file to import task
POST /rest/imports/{import_id}/tasks
Files: towns.shp, towns.shx, towns.dbf (multipart form-data)
# Step 3: Execute import
(no payload)
# Step 4: Execute task
POST /rest/imports/{import_id}/tasks/{task_id}
(no payload)
1.2 The SLD upload handling - (workspace is empty):
# Check if style exists
GET /rest/workspaces/city/styles/towns.json
# Since workspace is empty, style doesn't exist ā CREATE NEW
POST /rest/workspaces/city/styles?raw=true&name=towns
Content-Type: application/vnd.ogc.sld+xml
[SLD XML content as raw bytes]
# Assign style to layer
PUT /rest/layers/city:towns
"layer": {
"defaultStyle": {
"name": "towns"
"enabled": true
2.1 To upload a layer - (workspace is not empty):
# Step 1: Create import job (SAME as Scenario 1)
POST /rest/imports
"import": {
"workspace": {
"name": "city"
# Step 2: Upload file to import task (SAME as Scenario 1)
# Step 3: Execute import (SAME as Scenario 1)
(no payload)
# Step 4: Execute task (SAME as Scenario 1)
(no payload)
2.2 The SLD upload handling - (workspace is not empty)::
# Since workspace already has styles, style likely EXISTS ā UPDATE EXISTING
PUT /rest/workspaces/city/styles/towns.sld?raw=true
# Assign style to layer (SAME as Scenario 1)
"layer": {
"defaultStyle": {
"name": "towns"
"enabled": true
In code block 1.2; is application/vnd.ogc.sld+xml correct ?
p.s.: in the above example it is a Shapefile that I am loading, but the same issue occurs for any format I use.
