Thanks aaime, that was really helpful. I managed to make a working example just throwing into a ImageMosaic a directory with dt0 files.
But I am getting some issues. I am building a longitudinal profile in a desktop application. If I use directly DTED0 files from my hard drive the results is the upper image. Using WCS the result is the image at the bottom.
You can see the WCS result is like from a lower resolution. I tried to see what options I have into WCS query but I don’t see anything I can use. Can this be fixed?
Do you think it is ok to just use dted files into ImageMosaic or should I first transform it to Geotiff or something like that?
