Users, roles are lost on geoserver container restart
I am running docker container for Geoserver with base image docker.osgeo.org/geoserver:2.28.0.
I observe that on container restart all users , roles etc created are gone, except amin user. On some investigation, I found that a possible culprit is update_crednetials.sh, as it overwrites, users, roles config with default values.
I want to confirm if my analysis is correct, and if yes, then what is possible workaround for this?
With Docker, it is normal for no data to be stored unless a persistent volume has been configured.
From https://github.com/geoserver/docker:
To use an external folder as your geoserver data directory.
docker run -it -p 80:8080 \
  --mount src="/absolute/path/on/host",target=/opt/geoserver_data/,type=bind \
  docker.osgeo.org/geoserver:2.28.2
An empty data directory will be populated on first use. You can easily update GeoServer while using the same data directory."
Actually I am already using external folder as data directory in my docker compsoe:
volumes:
- ./geoserver_data:/opt/geoserver_data
Data is persistent into files like
/opt/geoserver_data/security/usergroup/default/users.xml.
But on restart, it gets overwritten by
/usr/local/tomcat/webapps/geoserver/data/security/usergroup/default/users.xml
I came across thsi on github page:
After the initial setup, it’s recommended to remove the GEOSERVER_ADMIN_USER and GEOSERVER_ADMIN_PASSWORD variable. Otherwise, newly added roles and users may be overwritten by the next time the container is restarted
I think this would help.
I wonder if the script could be updated to only set these values once somehow? Perhaps check the file contents and see if those values are already in use?
