using tcsh with GRASS ??
Has anyone experienced problems using tcsh for the GRASS interface ??
Mine seems to dive-bomb, putting me outside the GRASS start-up
script for some odd reason.
I can't really elaborate on the problem too much. I am unsure as to
which flavor of tcsh we have (we may be going to the *REAL* tcsh, as
our computer jockeys say), and have been unable to track down the
specifics at this point. I'm doing the usual post first, figure it out
later sort of thing.
Any info (or flames) greatly appreciated,
Jim Gasprich jimg@ocean.rutgers.edu
Center for Remote Sensing and tel -> (908) 932-9631
Spatial Analysis, Rutgers U. fax -> (908) 932-8644
Are you using GRASS 4.1beta or 4.0? In the first case, support for tcsh
is built in and you should have no problems as long as your tcsh is working
correctly. If you use 4.0 the startup script needs some minor modifications
to work right. I made these modifications, so if you need it you can email
me.
Hope this helps
Ferdinando Villa, dr.
Institute of Ecology Direct phone: +39-521-905615
University of Parma FAX: +39-521-905665
Viale delle Scienze e.mail: villa@eagle.bio.unipr.it
43100 Parma, Italy villa@sparrow.bio.unipr.it
