v.digit problem
GRASS net--
We're having a problem with v.digit's display window. When we enter
control points, chech registration, and define the digitizing window we
seem to have a scaling problem in one direction (either the X or Y,
depending on how we set up the map). V.digit creates a long skinny
window whose coordinates do not match the digitizing window we
entered. After this point, we can digitize normally, points returned
from the digitizer have the correct map coordinates, etc., but they
fall outside the bogus digitizing window on the graphics monitor.
Please help! We have run out ideas.
Michael Camann camann@dial.pick.uga.edu
Department of Entomology camann@phoenix.cs.uga.edu
University of Georgia (706) 542-1388
Athens, GA 30602 (706) 542-2276
I have never heard of this problem, and I do my digitizing in UTM.
But, with that disclaimer, what happens if you set your windowing device
to mouse as opposed to your digitizing tablet? You could then
reset your window without reference to the coordinates on your map.
