v.in.arc - file reading
A directory has been set up called arc in mapets. Within this directory
are the data files needed for an unlabeled polygon. When v.in.arc is run
the messages 'file could not be open for reading' or 'cannot find
ARC/INFO lines file <ffbndr.dat>'. The file is an ascii text file and is
ungenerated. It is in the proper format for a .pol file as well. Any
suggestions on why these files appear unreadable would be greatly
appreciated.
Thanks
Greg Baxter
