Dear Jazzman (a.k.a. Justin Hickey):
Thank you for your following response.
But my Grass4.1.5 is 'GRASS 4.1 Dynamic Binary Release Update 5' downloaded
from
ftp://129.229.103.1/pub/grass/grass4.1/release/binary/sun4/ .
Is the Update5 not fixed the v.support problem ?
At 0:25 PM 96.8.29 +0000, Justin Hickey wrote:
Iwao
On Aug 29, 11:23am, Iwao NODA wrote:
Subject: v.support of GRASS4.1
I have been a user of GRASS4.0. Recently I installed GRASS4.1 on SUNSPARCipx.
The command v.support makes an error message as follows. That is after the
execution of v.in.arc or v.in.ascii.--------------
(snip)
V.SUPPORT:
sh: 2886 Memory fault
ERROR(v.support): Could not build vector file: '10-2id8'-- End of excerpt from Iwao NODA
This may be caused by a known problem with v.support. You may want to try
getting a fix for v.support from the GRASS FAQ home page at:http://www.cecer.army.mil/grass/faq.html
Question 9 of the FAQ (the last one) deals with v.support crashing. The answer
to that question provides a link to new source code and the steps required to
link it to grass.This may fix your problem.
Iwao Noda
Research Scientist
Forest Management and Economics Laboratory
Kyushu Research Center
Forestry & Forest Products Research Institute
Kurokami 4-11-16, Kumamoto 860, JAPAN
Fax: JAPAN(096)344-5054
Internet : noda12@ffpri-kys.affrc.go.jp
