My efforts to compile the grass.rim and grass.tiger code from the src.garden
directory both fail because they cannot find the file Vect.h. The vect_map.c
routine in v.db.rim also includes the header file vect.h which it does find.
I cannot find Vect.h anywhere in my GRASS directory tree, and vect.h does not
contain the definitions vect_map.c needs. Any help?
allan
