Vector lines to areas
        I have a vector file of lines only, These lines form a set of basins.
I need to make a mask such that there is only one or as many as the user wishes
basins visible. The problem is that since there are only lines, how to get
areas out of them and then I was thinking that I could make a mask by running
v.to.rast. Any suggestions ???
Nalneesh Gaur
  There are two things you could try.
  Using v.digit program, "Edit" sub-menu allow you to swith the type of
vector line from line to polygon bouaries. If the number of polygons are not
a lot, this is the easy way to solve the problem.
  If the number of polygons are a lot, you may also try to use v.out.ascii
to generate the vector ascii file then doing some global replacement if you are
familiar with GRASS vector ascii file structure. If you have a problem to work
out this way, please write me a E-mail directly.
Song Wang Phone: (501) 575-6159
CAST/NCRI Fax: (501) 575-3846
12 Ozark Hall E-Mail: wang@cast.uark.edu
University of Arkansas
Fayetteville, AR 72701
