I would appreciate if some one can address why I am getting a huge
difference in statistics between a raster and a vector map.
The vector map is a streams map and I ran through v.report and found
24 Million meters of length. Then I converted the vector to raster
at 100x100m grid and ran the r.report to find how many cells are there
in that stream, and found 0.12 Million meters and then if I multiply
0.12 with 100 meter side of the grid I get only 12 Million meter length
stream, even if I multiply by the sqrt(2)*100*0.12, I get only 17 Million meters.
I looked at the v.report code and found the program is using
hypot - Euclidean distance routine
#include <math.h>
double hypot(x, y)
double x, y;
DESCRIPTION
hypot() returns
sqrt(x*x + y*y)
to find the distance between two points.
Can any one have similar experience? I streams are not much complex, these
are pernnieal streams.
Thanks in advance.
Srinivasan
srin@brcsun0.tamu.edu
