FYI, we have now moved all the event listings from the wiki over to the
new Drupal site: http://www.osgeo.org/event.
-mpg
-mpg
Note it is also now available as an RSS feed:
http://www.osgeo.org/event/feed
Consider it beta until you've tried it for a few months.
Also, if you want/need to post event items, let me or Michael know. We can post them or give you a login to do it (though log in mechanism is in flux at the moment).
Tyler
new Drupal site: http://www.osgeo.org/event.-mpg
Viscom-dev mailing list
Viscom-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/viscom-dev
http://www.osgeo.org/event/feedConsider it beta until you've tried it for a few months.
Very nice! Please consider to
- use only 1 timezone (currently mixture)
- select UTC/GMT as this reference timezone as "vendor neutral"
mechanism is in flux at the moment).Tyler
> the
> -mpg
> http://lists.osgeo.org/mailman/listinfo/viscom-dev_______________________________________________
Open Source Geospatial Foundation
http://osgeo.org/grass
I had trouble with the timezone stuff when I added them -- I was able to set a "user locale" sort of thing, but then everything got wierded out.
I asked Frank/Tyler if "time" could be an optional field for this very reason, but it turned out to be nontrivial.
I will try and resolve on Monday.
-mpg
-----Original Message-----
From: viscom-dev-bounces@lists.osgeo.org on behalf of Markus Neteler
Sent: Sat 1/27/2007 1:43 AM
To: Visibility Committee Discussion List
Subject: Re: [Viscom-dev] Event listings updated
> the
> -mpg
OK, I have updated all events to reflect their local timezones, and if
the event start/end time is not known I have used 00:00/23:59.
(Interestingly, when you go to create a new event the start/end times
seem to get set to random values...)
-mpg
[mailto:viscom-dev-bounces@lists.osgeo.org] On Behalf Of
Michael P. Gerlek
Sent: Saturday, January 27, 2007 3:35 PM
Subject: RE: [Viscom-dev] Event listings updatedI had trouble with the timezone stuff when I added them -- I
everything got wierded out.I asked Frank/Tyler if "time" could be an optional field for
this very reason, but it turned out to be nontrivial.I will try and resolve on Monday.
-mpg
Subject: Re: [Viscom-dev] Event listings updatedOn 1/26/07, Tyler Mitchell <tylermitchell@shaw.ca> wrote:
> Consider it beta until you've tried it for a few months.Very nice! Please consider to
- select UTC/GMT as this reference timezone as "vendor neutral"Markus
> Tyler
wiki over to
> > the
> > -mpg
