Voting: GSIP 240 - GitHub Actions for Documentation Deployment
Hi all
I would like to propose GSIP 240 - GitHub Actions for Documentation Deployment for consideration (and discussion at today’s PSC meeting). If possible, please give it a read before then.
Overview
Migrate GeoServer documentation builds from Jenkins to GitHub Actions following the approved GSIP 221 (MkDocs Migration). Jenkins could continue building after RST removal with additional reconfiguration work, but GitHub Actions provides superior maintainability through version-controlled configuration and eliminates SSH credential management.
Key Benefits:
  • Version-controlled configuration: YAML in Git (reviewable, auditable) vs Jenkins UI (manual)
  • No credential management: GitHub tokens (automatic) vs SSH keys (manual rotation)
  • Faster deployment: Immediate trigger (<10s) vs polling (0-5 min delay)
  • Better maintenance: Git-tracked changes vs manual Jenkins UI edits
Thanks
Peter
The updated GSIP is now much shorter @aaime GSIP 240 · geoserver/geoserver Wiki · GitHub
Some feedback on the proposal itself:
  • As written it buries the lede somewhat - the change in hosting from OSGeo to GitHub Pages is in my opinion just as important (if not more so) as the change in build system, but isn’t explicitly described until partway through the “Build Infrastructure” section.
  • Along similar lines, one downside in changing to GitHub Pages is that we will no longer have ownership (“we” being OSGeo as a whole) over the build or hosting infrastructure. While I think the ease-of-maintenance gained here is worth the loss of ownership, it would still be worth calling out as a downside in the proposal.
    I do think these tradeoffs are still worth it for a faster and easier docbuild, so I’m still giving my +1 to this proposal, but it would be nice if they were called out more clearly.
Torben
On Tue, Mar 10, 2026 at 11:59 AM Peter Smythe <noreply@discourse.osgeo.org> wrote:
Someone replied to a topic you are Watching.
Peter
March 10
Visit Topic or reply to this email to respond.
You are receiving this because you enabled mailing list mode.
To unsubscribe from these emails, click here.
Thank you for the insights @tbarsballe . They are much appreciated.
  1. Loss of ownership - is this important to the project (historically, before I got involved)? If so, then I think it’s definitely worth spending the time to update the build Docs job in Jenkins - I can tackle this next. The downside is the lack of version-controlled configuration, but perhaps these Jenkins jobs can be added as a folder in the GeoServer · GitHub repo (but they’re likely to get out of sync).
  1. Is the proposed change in hosting from OSGeo to GitHub pages seen as positive or negative? Do we have a CDN in front of OSGeo?
Thank you for your support, but I would like your input on what is important to the project.
Peter
+0.
Makes sense, but I know we’ll have to maintain the documentation for the 2.x series for a while, just because many will be shy to update (I don’t expect the 2.x series to really end in march 2027, but we’ll see). So it means we’ll have to perform manual backports of anything that involves documentation, and rewrite from MD to rst, for at least 1 year, possibly more.
Hence, my lack on “enthusiams” in the vote.
+0
+1
Answering inline:
I’m honestly not certain how important we consider this to the project. It has actually been a pain point in the past - previously, we were hosting many GeoServer resources on infrastructure owned by BoundlessGeo (formerly OpenGeo), and when that company got acquired/dissolved, it was a significant effort to regain control of several parts of that. See also the problems we are currently experiencing with old artifacts hosted on SourceForge. I don’t think these particular issues are a serious concern for this partucular change, given the nature of GitHub, and believe in this case the degree to which this makes our work easier is worth it.
General ownership concerns might be a good discussion point for our next PSC meeting.
Good question. I personally would consider it neutral on balance (likely better speed, at cost of less control/flexibility). The CDN question I don’t have an answer for, perhaps something to ask the OSGeo SysAdmin team.
Torben
+1 as I find github actions somewhat easier to maintain.
I am not that concerned about using github pages for hosting; the action could just as easily upload to OSGeo (osgeo could checkout the gh-pages branch and host that).
As for the double work of maintaing docs for 2.28; it may work out fine, as the older docs need their own screen snaps and instructions anyways.
Jody
+0.5
I think Jody’s point about us needing to maintain two sets of docs due to the UI changes swings me slightly in favour.
Ian
