The way I would approach this is have a buffer layer where 1 = 100' from
steams and 2 = 200' from steams. Then I would use r.mapcalc and its
logical if, then statements to access slope coverage and buffer coverage to
develope the third coverage, the "weighted buffer".
Bruce Wylie
From: MX%"grassu-list@max.cecer.army.mil" 9-DEC-1992 16:46
To: WYLIE
CC:
Subj: Weighted Buffers?Return-Path: <grass-lists-owner@max.cecer.army.mil>
Received: from max.cecer.army.mil by GPSRV1.GPSR.COLOSTATE.EDU (MX V3.1) with
SMTP; Wed, 09 Dec 1992 16:46:23 MST
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA29733
(5.67a/IDA-1.5); Wed, 9 Dec 1992 17:45:13 -0600
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id
AA22554; Wed, 9 Dec 92 17:38:33 CST
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id
AA12490 (5.67a/IDA-1.4.4 for <grassu-people@amber>); Wed, 9 Dec 1992
17:38:32 -0600
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id
AA22548; Wed, 9 Dec 92 17:38:28 CST
Received: from sprintf.merit.edu by max.cecer.army.mil with SMTP id AA29599
(5.67a/IDA-1.5 for <grassu-list@max.cecer.army.mil>); Wed, 9 Dec 1992
17:38:29 -0600
Received: by sprintf.merit.edu (5.64/1123-1.0-X.500) id AA15117; Wed, 9 Dec 92
17:46:14 -0500
Received: by sprint.com (SXG 6.0/scanf.7) with X.400 id 00f9bQkua001; 9 Dec 92
22:45:39 UT
Date: 9 Dec 92 20:37:46 UT
/S=E.ODOHERTY/OU=R02F06A/PRMD=USDA.FS.X400/ADMD=TELEMAIL/C=US/@sprint.com
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
To: /OU=R02F06A/PRMD=USDA.FS.X400/ADMD=TELEMAIL/C=US/@sprint.com
Subject: Weighted Buffers?
Message-ID: <"PL-IXSFJG"*@sprint.com>I have a friend with a question who is not on the network yet, but
here is the question:
I need to know if GRASS can do weighted buffers, and if so what
command(s) you use to do it. Example: a buffer around streams
where if slope is greater than 40% and the ground cover is trees, the
buffer should be 200', but if the slope is less than 40% slope and
the ground cover is grass, the buffer should be 100'. Clear as mud?
Thanks for any input!!
