WMS - 120 ortoimagery geotiffs (200 Gigabytes) as one layer - is that possible with Geoserver?
I’m new to geoserver with quite long background in serving maps with ESRI platform. I need to use geoserver to serv many big/large geotiffs as one layer. I have calculated pyramids for all of them. Using ImageMosaic plugin does not seem to be the option - it is very slow. So I publish each geotiff individually (works as charm) and create a group layer with all of them. And then the performance is very low. I am out of ideas.
Can geoserver be used as a tool for serving such amount of raster data as one layer?
Bart
I can reccommend the techniques listed in https://www.slideshare.net/slideshow/geoserver-on-steroids-foss4g-2015/53003393#2 and for OrthoImagery it’s worth reading https://blog.cleverelephant.ca/2015/02/geotiff-compression-for-dummies.html (which is hinted at in Andrea’s slides).
Ian
Hi Bart,
It’s absolutely possible to publish your 200 GB of geotiffs as a single imagemosaic layer.
We have an imagemosaic layer comprised of 531 individual geotiffs (stitched seafloor imagery mosaics collected from AUVs). Each tiff represents a single AUV deployment and ranges from a few MB to 25 GB. The total collection is ~1.4 TB.
Each tiff is preprocessed into a Cloud-Optimised Geotiff using GDAL (see GDAL help). We chose lossless DEFLATE compression as we weren’t sure what the potential future use of the files would be (there was a whole processing pipeline involved to assemble the stitched mosaics from thousands of tiny tiles with custom CRS’s). But as Ian’s second link indicates, JPEG compression may be well suited to your imagery. We used the default COG pyramids, but there are many processing options available.
Converting your geotiffs to COG format will be essential. When you say you have “calculated pyramids”, have you just build pyramids for your tiffs, or are they written as compliant COGs? For fast GeoServer performance with large tiffs, proper COGs are really important. These use internal tiling, embedded overviews, HTTP range requests, small targeted reads rather than full-file reads, header/metadata layout that supports early access, and compression suited to tiled random access.
To publish as an imagemosaic in GeoServer, we accepted all defaults except for the following changes (see Geoserver help here):
  • footprint behaviour = cut
    (avoids non-transparent areas being rendered outside of the granules)
  • set’ ‘maximum number of granules to load’ = 100
    (coverage is all of Aus and the individual granules / tiffs themselves cover only a very small spatial area, so there was no need to ever load all granules at once)
  • disabled ‘Use deferred loading ImageRead’.
    This setting controls how GeoServer reads the individual granules in the mosaic. When enabled, GeoServer streams data and only loads what’s needed during processing. When disabled, GeoServer reads directly and loads the requested data into memory. You may want to experiment with this - originally each of our tifs was sliced up into thousands of smaller tiles, and having this setting enabled was causing “too many open files” errors. If your GeoServer instance doesn’t have much memory available, you may want to enable this instead. 120 granules shouldn’t cause a “too many open files” issues.
This is our single imagemosaic layer [openlayers link] - you won’t see anything here as the granules are tiny (it’s hard to “find” them), but we use this to CQL filter the layer based on a number of custom properties we’ve added to the imagemosaic footprint shapefile.
This is a layer group of the same single imagemosaic layer, with a second vector layer (zoom-based styling) to help locate the small granules [openlayers link]. You can see this is pretty quick.
This imagemosaic WMS is used for annotating seafloor biota in a downstream platform, so it needs to be fairly zippy. We’ve not had any issues with this configuration.
If useful, the entire collection used to generate the single imagemosaic layer is here.
Hope this helps. Happy to share any more of our learnings.
Emma
Thanks Ian,
do I need any plugin to publish COG file on Geoserver? I get the following error whem adding it using option Raster Data Stores > GeoTIFF:
Could not list layers for this store, an error occurred retrieving them: Failed to create reader from file
Thanks, Bart
Hi Emma,
thanks for extensive reply! I will do further tests with my dataset.
Bart
Yes, the COG community module: COG (Cloud Optimized GeoTIFF) Support - GeoServer Documentation
Peter
Important reminder, a COG is just a well organized GeoTIFF. One does not need the COG module if the “COG” is stored on the local or network filesystem, it’s only needed if the COG is stored in cloud blob storage (S3, Azure blobs, GCS). A move to blob storage will reduce costs at the expense of performance, in a very visible way for the case of a hundreds of GB file, much less so smaller files.
See also the COG client configuration properties, if you decided to use blob storage.
