Hello QGIS users,
I’m writing to introduce Qtiler, a new open-source tool from MundoGIS for generating, inspecting, and publishing WMTS/XYZ tile caches from QGIS projects.
Short summary
Project: Qtiler (MundoGIS) — https://github.com/MundoGIS/Qtiler
Purpose: convert QGIS projects into tile caches (WMTS/XYZ), create Capabilities, and publish results so they can be added back into QGIS or used in web mapping clients.
Why you might try it
Speed up visualization by serving pre-generated tiles rather than rendering on the fly.
Share styled maps from QGIS as WMTS/XYZ across teams and web apps.
Inspect caches and capabilities via the included web UI.
Basic workflow
Prepare a QGIS project (.qgs or .qgz) with the layers/styles you want.
Use Qtiler (see README) to generate the cache and Capabilities.
Add the created WMTS/XYZ endpoint in QGIS (Layer → Add Layer → Add WMS/WMTS Layer or Add XYZ Tiles).
Repository:
- Main repo: https://github.com/MundoGIS/Qtiler
Request for feedback We would greatly appreciate:
Testing with different CRSs, large vector datasets, and various styling scenarios.
Reports of any issues or missing documentation in the repo issues.
Suggestions on whether a Processing script or full plugin would be more useful for the community.
If there’s interest, we can submit a tutorial to the QGIS documentation or prepare a Processing script / minimal plugin for easier installation. We’re also available to demo the workflow on a short presentation or meeting.
Thanks for your time — looking forward to feedback.
Best regards, MundoGIS https://github.com/MundoGIS/Qtiler contact: abel.gonzalez@mundogis.se
