Hi I am trying to add Cloud Optimized GeoTiFF (COG) into my Geoserver instance. I used the geoserver-docker build using 2.27.x version. My COG is uploaded in Google Cloud Storage (GCS). I have tried adding smaller dataset and found no issue. However, when I am trying to add larger data <100 MB, the server does NOT STOP loading, seen from below image.
There are no logs found for this issue.
Does anyone know what is this issue about and how can I resolve it?
When I shut the container, and restart it. I will find the data added. However, when I add it to Layers, it will again not stop loading. Thus, I am not able to save add it as as layer.
When I try to delete the store, there will be an error.
java.lang.RuntimeException: Failed to upgrade lock from read to write state, please re-try the configuration operation
at org.geoserver.GeoServerConfigurationLock.tryUpgradeLock(GeoServerConfigurationLock.java:192)
at org.geoserver.catalog.LockingCatalogFacade.invoke(LockingCatalogFacade.java:34)
at jdk.proxy3/jdk.proxy3.$Proxy41.remove(Unknown Source)
at org.geoserver.catalog.impl.CatalogImpl.remove(CatalogImpl.java:226)
at org.geoserver.security.SecureCatalogImpl.remove(SecureCatalogImpl.java:1367)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.remove(AbstractFilteredCatalog.java:770)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.remove(AbstractCatalogDecorator.java:97)
at org.geoserver.catalog.CascadeDeleteVisitor.visitStore(CascadeDeleteVisitor.java:89)
at org.geoserver.catalog.CascadeDeleteVisitor.visit(CascadeDeleteVisitor.java:99)
at org.geoserver.catalog.impl.ModificationProxy.accept(ModificationProxy.java:187)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:147)
at jdk.proxy3/jdk.proxy3.$Proxy46.accept(Unknown Source)
at org.geoserver.web.data.SelectionRemovalLink$1.onSubmit(SelectionRemovalLink.java:66)
at org.geoserver.web.wicket.GeoServerDialog.submit(GeoServerDialog.java:99)
at org.geoserver.web.wicket.GeoServerDialog$1.onSubmit(GeoServerDialog.java:110)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:112)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:249)
at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1374)
at org.apache.wicket.markup.html.form.Form.process(Form.java:1036)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:860)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:202)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:154)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:630)
at org.apache.wicket.core.request.handler.ListenerRequestHandler.internalInvoke(ListenerRequestHandler.java:300)
at org.apache.wicket.core.request.handler.ListenerRequestHandler.invoke(ListenerRequestHandler.java:274)
at org.apache.wicket.core.request.handler.ListenerRequestHandler.invokeListener(ListenerRequestHandler.java:222)
at org.apache.wicket.core.request.handler.ListenerRequestHandler.respond(ListenerRequestHandler.java:202)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:910)
at org.apache.wicket.request.RequestHandlerExecutor.execute(RequestHandlerExecutor.java:63)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:294)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:255)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:277)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:208)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:555)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:199)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:144)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:168)
at org.apache.catalina.filters.CorsFilter.handleSimpleCORS(CorsFilter.java:240)
at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:152)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:67)
at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:36)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:181)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:352)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.AuthorizationFilter.doFilter(AuthorizationFilter.java:100)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:89)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:361)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:126)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:120)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:52)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:227)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:221)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:117)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:110)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:101)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:66)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:225)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:190)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:139)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.geoserver.filters.SecurityHeadersFilter.doFilter(SecurityHeadersFilter.java:116)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:168)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:482)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:656)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:346)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:397)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:935)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1792)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1189)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:658)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
at java.base/java.lang.Thread.run(Thread.java:840)
