xdigit, I'm debbugging currently
< I downloaded GRASS4.1 source code from CERL ftp site a month ago
<and compiled on USL UNIX SVR4.2. While compiling xdigit part, there are
<no error msgs. But when I try to execute it (under grass prompt, type
<in xdigit) I get the following error msgs:
< X Error of failed request: BadValue(integer parameter out of range
< for operation)
< Major opcode of failed request: 53 (X_CreatePixmap)
< Value in failed request: 0x0
< Serial number of failed request: 413
< Current serial number in output stream: 415
We have the same problem compiling under Sun OS 4.1.3
on a Sparc 10.We have not found a solution as yet.
What Motif libraries are you using?
Please let us know if someone reports a solution.
   Rod Paterson
   EMail rgp@aberfoyle.oz.au
Hello,
  I'm just compiling XGRASS4.1 on LINUX using Motif 1.2.2.
  Before I compiled XGRASS on SGI INDIGO and SPARC 10 without
  any problems. All XGRASS programs are running on this machines.
  On LINUX I have the same problems as You.
  Meanwhile I found the reason of the problem, but not the solution.
  XDIGIT:
    there is a program called custommenu.c wich calls
      cmenu = make_colors_menu (parent):
    If I change this line into a comment, XDIGIT comes
    up (but there are some functions missing).
    make_colors_menu is defined in xcolor.c. The
    critical positions in xcolor.c are:
      XtSetArg(wargs[n], XmNlabelPixMap,
        XmGetPixmap(XtScreen(parent), names[i],
        fg, bg));n++;
        -> XmGetPixmap does not find the pixmap defined
           by names[i].
      XtSetArg(wargs[n], Xmbackground, dcolors[i]);n++;
        -> dcolors[i] causes here an error
    I'm currently not so familiar with programming in X, that
    I will solve the problem quick. I (We) need some help form
    experienced X programmers!
  My current configuration:
  LINUX SLS 1.03
  Kernel 99PL14
  Libs 4.4.4
  GCC 2.4.5
  compiling options
  -DXM_1_1_BC -traditional ...
      | |------------> no ANSI C
      |------------------------> backward compatibility to MOTIF 1.1
