XGRASS on MOTIF 1.2.2
On Nov 10 1993 Andreas Holz <asholz@cip.informatik.uni-erlangen.de> wrote:
Hello GRASS-Users,
  is there someone, who compiled XGRASS on MOTIF 1.2.2?
  Is there a patch list?
I've tried but it failed (for SunOs 4.1.1). Recently I discovered the
following lines in /usr/include/Xm/XmP.h:
  #ifdef XM_1_1_BC
  /* The following symbols are OBSOLETE and SHOULD NOT be used.
   * They are provided here as a source compatibilibity convenience,
   * to support the transition to the Motif 1.2 source environment.
I didn't find the time to try it out myself but the following should
solve part of the problem:
Add -DXM_1_1_BC to the line XCFLAGS = ... in your gmake head file
(...../grass/src/CMD/head/<architecture>). But check out XmP.h first,
it also checks for XmNO_BC_INCL.
Good luck, Raymond
