xgrass4.1
When I run xgrass4.1 on Sun sparc IPC (Sun OS 4.1.x, OW3)
First I get a long list of warning messages as shown below
and then I get the XGRASS Startup Dialog window.
Backe space delete keys do not produce the right effect.
When I installed the binary version, as far as I know, I followed
the installation instructions very carefuly.
Some one has adviced me to run a trace
So I typed
trace xgrass4.1
In the long list of output I found the following lines
select (4, 0xf7ffe508, 0, 0, 0) = 1
read (3, "".., 32) = 32
open ("/grass.src/X11R5/lib/X11/XKeysym".., 0, 077) = -1 ENOENT (No such file or directory)
open ("/grass.src/X11R5/lib/X11/XtError".., 0, 06112410) = -1 ENOENT (No such file or directory)
Can any of you help me?
Thanks
Thiru
N.Thirugnanasothy Tel. No. 0274 383323
Computer Centre, Fax. No. 0274 304354
University Of Bradford,
Richmond Road,
Bradford, West Yorks.,
BD7 1DP., UK
Warning: translation table syntax error: Unknown keysym name: osfActivate
Warning: ... found while parsing '<Key>osfActivate: ManagerGadgetSelect() '
Warning: translation table syntax error: Unknown keysym name: osfSelect
Warning: ... found while parsing ' <Key>osfSelect: ManagerGadgetSelect() '
Warning: translation table syntax error: Unknown keysym name: osfHelp
Warning: ... found while parsing ' <Key>osfHelp: ManagerGadgetHelp() '
Warning: translation table syntax error: Unknown keysym name: osfBeginLine
Warning: ... found while parsing '<Key>osfBeginLine: ManagerGadgetTraverseHome()'
Warning: translation table syntax error: Unknown keysym name: osfUp
Warning: ... found while parsing ' <Key>osfUp: ManagerGadgetTraverseUp()'
