XKeysymDB Problems
Hey,
I have recently downloaded the binaries for Sun4 and seem to have them up
and running. I am having a problem however. Whenever I run xgrass4.1 I get
several dozen messages like the following:
dotson@bud%
dotson@bud%
dotson@bud% xgrass4.1
Warning: translation table syntax error: Unknown keysym name: osfActivate
Warning: ... found while parsing '<Key>osfActivate: ManagerGadgetSelect() '
Warning: translation table syntax error: Unknown keysym name: osfSelect
Warning: ... found while parsing ' <Key>osfSelect: ManagerGadgetSelect() '
Warning: translation table syntax error: Unknown keysym name: osfHelp
Warning: ... found while parsing ' <Key>osfHelp: ManagerGadgetHelp() '
I looked at the file XKeysymDB.motif and confirmed that the defs are
in /usr/openwin/lib/XKeysymDB where I think the should be. (they were
already there). When I run grass from a SUN, I get all these messages
and then the it hangs. I did a "setenv DISPLAY bud:00" to get the
DISPLAY in the right place and even did a "xhost +" just to make sure.
No display, it just sits there. When I run from a Hummingbird X server
from a PC, grass comes up and I can display map etc. Text entry is
a bit goofy (backspace doesn't work right) but I assume this is from the
keysym problem. I still get all the error messages but GRASS comes up.
The Hummingbird X Server also has a XKeysymDB type file with a slightly
different format than the SUN but I included the XKeysymDB.motif entries
in there as well.
Anybody have any ideas on this? Please send me a reply directly since
I am not currently on the grassu-list mailing list.
Thanks Alot,
Doug Dotson, Engineer
Tate Integrated Systems, L.P.
dotson@tate.com
