Cascade WMS failing in v3.0.1
Hello
We had a cascaded WMS working in 2.28.5. After upgrade to 3.0.1, it is failing to load in a WMS client (QGIS). The remote WMS loads fine in QGIS direct without Geoserver cascading it. It appears to be timing out after a long delay in QGIS. Log includes:
  • Error rendering coverage on the fast path
    • Caused by: org.geoserver.platform.ServiceException: org.apache.hc.core5.http.ConnectionRequestTimeoutException: Timeout deadline: 180000 MILLISECONDS, actual: 180000 MILLISECONDS
    • Caused by: org.apache.hc.core5.http.ConnectionRequestTimeoutException: Timeout deadline: 180000 MILLISECONDS, actual: 180000 MILLISECONDS
  • Rendering process failed
    • Caused by: org.apache.hc.client5.http.impl.classic.RequestFailedException: Request aborted
    • Caused by: java.lang.InterruptedException
Possibly also:
  • Can’t obtain the schema for the required layer
    • Caused by: java.lang.UnsupportedOperationException: Server does not specify a GetLegendGraphic operation. Cannot be performed
[Not sure on etiquette of posting long stack traces here]
Thanks to a reply from Jody, I’ve tried disabling URLChecks, but that has not fixed the issue.
Can anyone help me discover where the issue lies?
Thanks
Tom
Thanks to Jody (again), confirmed that the issue is with schema access restrictions: setting ENTITY_RESOLUTION_UNRESTRICTED=true brings the layer to life, but is not suitable for production. I’ll see if I can find which calls are not being matched by my URL check.
The positive result with ENTITY_RESOLUTION_UNRESTRICTED=true might have been a false positive. I appear to be experiencing the issue intermittently. I have a few follow-up questions, if anyone can help me (I appreciate some of these are not pure Geoserver questions):
  • In the Geoserver admin interface (Security > URL Checks), does checking or unchecking “URL checks are enabled” take immediate effect? There is no save button.
  • I am trying to write a regex to allow the remote WMS in URL Checks. When I test a URL against it in Geoserver admin (Security > URL Checks > Test URL Checks with external URL), it does not match. When I try to use regex101.com, it matches (I’ve tried PCRE, Java, and Javascript options, and tried removing both /g and /m flags which it enables by default). How do I find out where the error lies?
  • Is there a method (Tomcat/Ubuntu) to add ENTITY_RESOLUTION_UNRESTRICTED=true without restarting the Tomcat service? I’ve tried adding it to /etc/environment, but since my attempts are proving inconclusive, it’s hard to know whether Geoserver observes that immediately.
Many thanks
Tom
Huh - It sounds like you may have an actual time out on the WMS service being accessed?
You could try using control-flow to avoid hitting the service concurrently if it is struggling to keep up with your requests (or limiting the number of requests you can make).
For your questions:
  1. The URL checks should have a save button?
  2. There are some examples in docs? You should be able to adapt for a WMS service:
`^https://host.whatever.net/path/to/service\?.*SERVICE=WMS.*?$
  1. There is no way to configure ENTITY_RESOLUTION_UNRESTRICTED without restarting tomcat, the point of such settings is to place them out side of administrator control.
    Especially for ENTITY_RESOLUTION_UNRESTRICTED=true setting is not to be used in production; but it was successful then you confirms that schema resolution was part of the problem to be fixed using entity resolution allowlist: ENTITY_RESOLUTION_ALLOWLIST=server1|server2
Some information from the remote WMS provider: they do not support GetLegendGraphic. This is confirmed in the GetLegendGraphic response from GeoServer:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE ServiceExceptionReport SYSTEM "https://xxx.xxx.com/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" >
  <ServiceException>
    Can&apos;t obtain the schema for the required layer.
  </ServiceException>
</ServiceExceptionReport>
Requesting the remote WMS directly in QGIS results in only GetCapabilities and GetMap calls, no GetLegendGraphic. The remote WMS’s response to GetCapabilities contains no GetLegendGraphic entity. Calls to the cascaded GeoServer layer, however, include GetLegendGraphic:
<GetLegendGraphic>
  <Format>image/png</Format>
  <Format>image/jpeg</Format>
  <Format>application/json</Format>
  <Format>image/gif</Format>
  <DCPType>
    <HTTP>
      <Get>
        <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="https://xxx.xxx.com/geoserver/wms?SERVICE=WMS&amp;"/>
      </Get>
    </HTTP>
  </DCPType>
</GetLegendGraphic>
Each layer also includes a GetLegendGraphic URL in Style.LegendURL.OnlineResource.
As a test, I also tried to configure the GeoServer WMS in QGIS with the option “Ignore GetMap/GetTile/GetLegendGraphic URI reported in GetCapabilities”. This seemed to make no difference.
Is it possible when configuring either the WMS cascade store in GeoServer, or the layer itself, to prevent GetLegendGraphic requests or to handle their response better in this situation?
Just to be clear, this layer worked in GeoServer 2.28.5, and failed on upgrade to 3.0.1.
Thanks
Tom
Issue also reported here:
The workaround proposed in that thread prevented the issue from recurring in production for me.
Thanks
Tom
