I tried to report this in the GEOT Jira, but my new account has no permission
to create issues. Could a maintainer grant me access (Jira user: [gebruikersnaam])
or create the ticket on my behalf? Full details below.
Environment:
GeoServer [versie], gt-http-commons [versie]
httpclient5 5.4.4, httpcore5 5.4.3
Eclipse Temurin 21.0.12.1, Apache Tomcat 11, Windows Server 2019
Problem:
With a cascaded WMS store using HTTP connection pooling, every response from the
remote server with a status other than 200 permanently consumes one connection
from the pool. Once max connections is reached, every subsequent request to that
store waits 180 s (default connection request timeout) and fails with
ConnectionRequestTimeoutException. The store never recovers on its own; only
saving the store or restarting GeoServer helps. In one occurrence the store was
unavailable for more than 26 hours. Blocked requests hold Tomcat threads, which
can eventually affect all services.
Root cause:
In MultithreadedHttpClient.get(URL, Map) and post(…), an IOException is thrown
for non-200 responses without closing the response, so the leased connection is
never returned to the PoolingHttpClientConnectionManager:
response = executeMethod(getMethod);
if (200 != response.getStatusCode()) {
throw new IOException("Server returned HTTP error code " + ...);
Proposed fix (get() and post()):
response.dispose();
Evidence:
Affected store: max connections = 12, read timeout 60 s, connect timeout 30 s.
The 180 s wait is unrelated to the store settings.
09:11:28 to 09:12:19: the remote server returned HTTP 500 exactly twelve
times. After the twelfth error, no further requests reached the remote server.
09:15:12: first ConnectionRequestTimeoutException:
at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.acquireEndpoint
at org.geotools.http.commons.MultithreadedHttpClient.executeMethod(MultithreadedHttpClient.java:200)
at org.geotools.http.commons.MultithreadedHttpClient.get(MultithreadedHttpClient.java:238)
at org.geotools.ows.wms.map.WMSCoverageReader.getMap(WMSCoverageReader.java:329)
Thread dump at 09:18:38: 209 threads, 93 of them parked in StrictConnPool
lease (acquireEndpoint), zero threads reading from a socket. The connections
are leased but unused, i.e. leaked.
Workaround:
Disable “Use HTTP connection pooling” on the cascaded WMS/WMTS store.
Applied to 26 stores in production.
Thanks you for investigating, for linking to my issue, and for finding this workaround. I can confirm that it appears to have removed the issue in production for us (based on a few days’ production usage).
Thanks for the detailed analysis, ArnoP. We ran into exactly the same issue on GeoServer 3.0.2: a cascaded WMS store (maxConnections 32) whose remote MapProxy returned HTTP 500 while one of its upstream sources was down. After 32 errors the store blocked completely, also for areas that were fine.
I’ve opened a pull request with the fix you proposed, plus unit tests for GET and POST:
The leak is a regression from the HttpClient 5 migration (#5392); the 4.x code released the connection before throwing. Like you, I couldn’t create a GEOT issue (new Atlassian account without permission), so the PR asks a maintainer to create one. A backport to 35.x is requested as well.
Until a fixed release is out, disabling “Use HTTP connection pooling” on the store works for us too.
