Reminder that the next PMC meeting is scheduled for tomorrow, February 24, at 18:30 CET.
I’ve got a conflicting meeting and will be unable to attend.
Torben
Unfortunately I can’t attend this time.
-Jukka Rahkonen-
jive
March 10, 2026, 5:34pm
3
GeoTools / GeoServer PMC meeting - 2026-02-24
Attending
David Blasby
Jody Garnett
Gabriel Roldan
Kevin Smith
Peter Smythe
Cécile Vuilleumier
Pierre Mauduit
Actions from prior meetings:
done: Peter can make a CITE landing page (to replace this ) with the new sticker, and thanking sponsors/in-kind
done: Andrea small spring 7 proposal mail for the record (mail here )
done: Peter static image of gs3 gauge update website and blog posts
Action: jody Make an email or proposal about this so we have a wider discussion about choice of mkdocs for 2.28.x (https://github.com/geoserver/geoserver/wiki/GSIP-221 updated, sending to discourse).
Agenda
GS3 Update
UI/UX Updates
Arm64 docker images
Mkdocs
ChitChat
Actions
GS3 Update
Dependency updates ongoing. Removed some dead code in GWC for previews never got used.
Cloud storage dependency hell across imageio-ext, gwc and 3 providers, AWS, Azure, Google. Each one of them wants a different version of Netty, which in turn results in more dependencies.
For a long time, we split the 3 providers in vanilla geoserver and Gabriel tried a “dependency converge” approach in GeoServer cloud.
Now new PRs to use a centralized BOM to manage these dependencies, and an approach that replaces Netty with other HTTP clients (that’s the role of Netty in the cloud deploys).
UI/UX Updates
Work is underway, see gs3-theme branch for progress. Still too early to preview!
Working on menus, responsive sizing
Discussion about table reducing to cards when not enough width
A fun css approach needs to generate magic columns
A lot of casual tables for layout are being convert to flexbox
https://github.com/geoserver/geoserver/pull/9113 (in progress) - validate HTML files add <div class=<fname>. Possible issues with multiple <wicket:panel> <wicket:fragment> <wicket:extension>
Quite a few wicket pages have a single panels
However some are fragments and extensions and a bunch different components (ie WPS request builder)
Fragments are designed not have a class around, they are component that you normally stick in a component, like a table row … or input element
Extensions, every time you takes base page you extend it
Also editor page tabs, and service page contributions, …
It is hard to identify a wicket component, no easy fix or convention, …
arm64 docker images
Q: Is it the same image names? Or different image names…
Same tag, different architecture (platform) are now available
Note the -gdal variant for each tag
Mkdocs
https://geoserver.org/geoserver/en/user/extensions/authkey/#installation
Shows {{ release }} - we need to turn on macro processing for that page?
Here is the example: https://geoserver.org/geoserver
