On Fri, Nov 24, 2017 at 1:09 PM, Niels Charlier <niels@anonymised.com> wrote:
Hi Steve,
You need to add a
<context:component-scan base-package="package.of.the.class" />
to the spring context for it to work.
Regards
Niels
On 24-11-17 09:20, Steve Omondi wrote:
So I temporarily removed security for the /rest/* chain in Authentication and using http://host:port/geoserver/rest/jdbcexport just returns the default geoserver/rest result.
Any pointers are welcome.
Kind regards,
Steve Omondi
Kind regards,
Steve Omondi
On Fri, Nov 24, 2017 at 10:51 AM, Steve Omondi <steve.omondi@anonymised.com> wrote:
Hi Niels,
So I was trying out the Java class you shared. Here is what I did;
→ copied theJDBCexport into geoserver/WEB-INF/classes/
→ restarted the Tomcat
→ Tried to invoke the class on the browser with the following URLs;
http://host:port/geoserver/jdbcexport resulted into 404 Not Resource not found
http://host:port/geoserver/rest/jdbcexport resulted into 403 Error (Forbidden) Note that I’m logged into Geoserver as Admin
Is this the correct procedure I should use with this class?
Kind regards,
Steve Omondi
On Wed, Nov 15, 2017 at 5:02 PM, Niels Charlier <niels@anonymised.com> wrote:
Steve,
Sorry for the confusion. This was not in response to you, but Andrea about dropping the module from geoserver altogether. I understand your decision because I have also found that jdbcconfig is a problematic bottle neck (but as I mentioned, mostly because of the poor cache support and the unnecessarily repetitive queries).
In the attachment you can find the code for exporting jdbc to hard drive. The file needs to be temporarily added to the class path and scanned by the spring appcontext, then when you are logged in as an admin you can call /jdbcexport from the browser to force the caching of the catalog. I hope you can use this somehow.
Kind Regards
Niels
On 15-11-17 12:51, Steve Omondi wrote:
Oh really, drop it? I thought jdbcconfig was the recommended way for clustering and is particularly useful when you are working with huge catalogs. I assumed it was actually being used in production by people.
Our intention is not to drop it entirely. But to run more or less a catalog that is based on XML for some specific workspaces that we really need to be performant urgently.
While we have found jdbcconfig to be an excellent solution for clustering, it
also
has made 3 Load balanced Geoserver 2.11.2 to be 6 times slower than 1 Geoserver 2.9 all other configurations kept constant.
And this is an issue that we can’t ignore in PROD for our case.
We intent to move a few of the workspaces and layers especially complex LayerGoups fron the JDBC catalog to achieve better performance over convenience of the DB Catalog.
Otherwise, JDBCConfig is an excellent module in use.
Kind regards,
Steve Omondi
On Wed, Nov 15, 2017 at 1:30 PM, Niels Charlier <niels@anonymised.com.4960…> wrote:
The main problem seems to be the performance issues though, as this email also proves, as well as both of the two PR’s that are open who are related to the same thing. But I believe this is rather solvable and would make a huge difference.
I can review these PRs no problem, since they are actually related to the work I am doing for this module.
Perhaps these improvements there can blow some new life into it.
Regards
Niels
On 14-11-17 20:10, Andrea Aime wrote:
Hi Niels,
today during the PSC meeting the topic came out of whether we should just drop
JDBCConfig, since:
- mails related to it are not really getting answered
- pull requests related to it are sitting there not getting reviewed
We still have to see if there is some interested, but we need someone to champion the module
just enough to make it worth keeping around (I’m not talking about immediate answers, it’s
a community/unsupported module, but at least some presence).
I’m also going to ping the people making pull requests.
On Tue, Nov 14, 2017 at 5:24 PM, Niels Charlier <niels@anonymised.com> wrote:
Hello Steve,
First I’d like to say I have been doing some work on considerable performance improvements for jdbcconfig. It happens to be the case that jdbcconfig doesn’t take good use of its cache and repeatedly sends the same queries over and over again. It looks promising but I still need to do some improvements and write some tests and I had other work coming on top of it. But this is definitely coming.
Also, I wrote some code in geoserver for myself to conveniently export the jdbc catalog back to the file system. I found a way to do this easily by firing a bunch of catalog change events to the file system catalog. However, I am not sure to make it easily available to end users at this point, I assume that just giving you the code won’t be very helpful for you. Perhaps we can work something out if you are interested.
Regards
Niels
On 09-11-17 11:02, Steve Omondi wrote:
Hi guys,
I have JDBCConfig enabled and connected to a Postgres DB. I have over 500 layers spread across different workspaces and layergroups.
After running performance tests for GetMap requests against this configuration versus XML Catalog based geoserver I really need to revert my catalog back to XML in GEOSERVER DAT DIR and probably share it using NFS.
Is their a method to export the Database Catalog (based on JDBCConfig) back to XML Catalog?
Kind regards,
Steve Omondi
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
[Geoserver-users@anonymised.comrge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
------------------------------------------------------------------------------ Check out the vibrant tech community on one of the world’s most engaging tech sites, Slashdot.org! http://sdm.link/slashdot _______________________________________________ Geoserver-users mailing list Please make sure you read the following two resources before posting to this list: - Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/ - The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html Geoserver-users@anonymised.comrge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
