[Geoserver-users] kml and TimeStamp
hi all,
i try to see my feature with google earth.
i add a time template :
${analysis_time.value?date}
My time field is mapped as :
analysis_time: dateTime
In kml data, i have timeStamp :
            <TimeStamp>
               <when>0008-04-10T00:00:00+01:00</when>
            </TimeStamp>
This strange date has nothing to do with my analysis_time in database...
any idea ?
thank again and again.
Sébastien Geindre
DPREVI/AERO/DEV
sebastien.geindre __at__ meteo.fr
Hi Sébastien,
What version are you using? I recently fixed a bug with kml timestamps.
Any chance you can grab a recent nightly build and try it there:
http://traffic.openplans.org/geoserver/trunk/
-Justin
Sébastien Geindre wrote:
hi all,
            <TimeStamp>
            </TimeStamp>
any idea ?
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Sébastien,
What type of database are you using?
You may need to specify a date format string in your template file.
See
http://docs.codehaus.org/display/GEOSDOC/02-Time+Templates#02-TimeTemplates-reference
When trying to determine the correct format string for a particular
date/time field, I found it useful to look at the log file when trying to
determine the exact date format string to use, because the log shows you how
your time or date data is interpreted before the template is applied.
- Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
Geoserver-users mailing list
View this message in context: http://www.nabble.com/kml-and-TimeStamp-tf4648184.html#a13290684
Tyler Erickson a écrit :
Sébastien,
i am using postgis, my analysis_time field is a timestamp.
data example :
<gml:TimeInstant>
       <gml:timePosition>2005-06-25T17:11:00.000Z</gml:timePosition>
</gml:TimeInstant>
You may need to specify a date format string in your template file. See
- Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
Sébastien Geindre
DPREVI/AERO/DEV
For the postgres data type ‘timestamp without time stone’ I have found the following time format string to work:
${analysis_time.value?datetime(“MM/dd/yy hh:mm a”)}
If that doesn’t work, post the postgres data type that you are using, and any log messages that you get for the WMS request.
Tyler A. Erickson, Ph.D.
Research Scientist
Michigan Tech Research Institute (MTRI)
3600 Green Court, Suite 100
Ann Arbor, MI 48105
Phone: 734-913-6846
Fax: 734-913-6880
tyler.erickson@anonymised.com
http://www.mtri.org
For the postgres data type 'timestamp without time stone' I have found the following time format string to work:
    ${analysis_time.value?datetime("MM/dd/yy hh:mm a")}
If that doesn't work, post the postgres data type that you are using, and any log messages that you get for the WMS request.
My log error :
19 oct. 15:27:47 ERROR [freemarker.runtime] -
Error: on line 1, column 3 in time.ftl
Expecting a date here, found: 16/10/07 13:00
The problematic instruction:
==> ${analysis_time.value?date("yyyy-MMM-dd hh:mm:ss")} [on line 1, column 1 in time.ftl]
so i set the format to "dd/MM/yy hh:mm" and it is better !!!
"dd/MM/yy hh:mm a" does not work.
i have a time schedule on google earth but the range is not valid....
always the same data :
<TimeStamp>
               <when>2007-10-19T00:00:00+00:00</when>
            </TimeStamp>
for 19/10/07 08:13 data...
still a bug ?
Sébastien,
data example :
<gml:TimeInstant>
</gml:TimeInstant>
- Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
*Tyler A. Erickson, Ph.D.*
Research Scientist
*Michigan Tech Research Institute (MTRI)*
Ann Arbor, MI 48105
*Phone:* 734-913-6846
*Fax:* 734-913-6880
tyler.erickson@anonymised.com <mailto:tyler.erickson@anonymised.com>
http://www.mtri.org
Sébastien Geindre
DPREVI/AERO/DEV
Based on your log, my guess would be:
    ${analysis_time.value?datetime("dd/MM/yy HH:mm")}
If that doesn't work, the following links may help you out find the correct
date format:
http://java.sun.com/j2se/1.4.2/docs/api/java/text/SimpleDateFormat.html
http://www.freemarker.org/docs/ref_builtins_date.html#ref_builtin_date_datetype
My log error :
<TimeStamp>
            </TimeStamp>
still a bug ?
Sébastien,
data example :
<gml:TimeInstant>
</gml:TimeInstant>
trying to
you how
- Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
database...
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
browser.
Research Scientist
Ann Arbor, MI 48105
*Fax:* 734-913-6880
http://www.mtri.org
Sébastien Geindre
DPREVI/AERO/DEV
View this message in context: http://www.nabble.com/kml-and-TimeStamp-tf4648184.html#a13298058
Hi Sébastien,
Did you try the nightly build?
My log error :
<TimeStamp>
            </TimeStamp>
still a bug ?
Sébastien,
data example :
<gml:TimeInstant>
</gml:TimeInstant>
trying to
you how
- Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
database...
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
browser.
Research Scientist
Ann Arbor, MI 48105
*Fax:* 734-913-6880
http://www.mtri.org
Justin Deoliveira
Justin Deoliveira a écrit :
Hi Sébastien,
i am on the trunk. i did a svn update on geoserver and geotools.
i still have
<TimeStamp><when>2007-10-19T00:00:00+00:00</when></TimeStamp>
with MM/dd/yy hh:mm format.
what could i check ???
how could i help ?
on Monday....
have a nice weekend...
thanks for all.
My log error :
<TimeStamp>
            </TimeStamp>
still a bug ?
Sébastien,
data example :
<gml:TimeInstant>
</gml:TimeInstant>
  - Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
Research Scientist
Ann Arbor, MI 48105
*Fax:* 734-913-6880
http://www.mtri.org
Sébastien Geindre
DPREVI/AERO/DEV
Justin Deoliveira ha scritto:
Hi Sébastien,
I looked at this quickly, it's the feature wrapper that
turns the date into a string using:
DateFormat.getInstance().format( (Date)o )
Once http://jira.codehaus.org/browse/GEOS-1393 is fixed
you'll have access to the native java.util.Date object
and you'll be able to format it as you like.
Hmmm... I am unable to replicate this behaviour with postgis and
timestamp fields. Simple using ${<timstampField>.value} works for me.
Andrea is correct in that having direct access to the raw date may be an
easier way to go. Although i dont think this will work with the kml
encoder out of the box.. i could be wrong.
Sébastien: Can you send me your table structure. And perhaps a subset of
the data in the table in which you are having problems with. I can try
replicating with your data.
-Justin
Hi Sébastien,
i still have
how could i help ?
on Monday....
thanks for all.
My log error :
<TimeStamp>
            </TimeStamp>
still a bug ?
Sébastien,
data example :
<gml:TimeInstant>
</gml:TimeInstant>
trying to
you how
- Tyler
hi all,
            <TimeStamp>
            </TimeStamp>
database...
any idea ?
Sébastien Geindre
DPREVI/AERO/DEV
browser.
Research Scientist
Ann Arbor, MI 48105
*Fax:* 734-913-6880
http://www.mtri.org
Justin Deoliveira
It may be that the french default DateFormat is different.
Locale matters when you use DateFormat.getInstance().
What I meant is that if you have the raw date then you
can apply whatever formatting you want using Freemarker
date format functions like:
http://freemarker.org/docs/ref_builtins_date.html
and then turn the raw date in whatever is the expected form.
Then again, I'm not too familiar with what happens in that
part of the code so I'm probably completely off...
Hi Tyler,
http://jira.codehaus.org/browse/GEOS-1393 is fixed, could you try an
updated version of trunk or the latest nightly?
attribute.value returns a default string representation of the value,
you can access the actual value object through attribute.rawValue
Gabriel
Gabriel Roldán
You will need to make sure that you use one of the supported formats
listed on this page:
Gabriel Roldan wrote:
Hi Tyler,
Gabriel
Justin Deoliveira
Sébastien will have to try out the fix, because he had encountered the
problem with the time templates. The time templates have been working fine
for me...
Tyler
Gabriel Roldán-4 wrote:
Hi Tyler,
Gabriel
an
Gabriel Roldán
View this message in context: http://www.nabble.com/kml-and-TimeStamp-tf4648184.html#a13328371
Good morning guys, and thanks for helping...
first i update my subversion repository.
and rebuild geoserver.
then, i try this ${<timstampField>.value}, it's better BUT, i lose the seconds...
for data : 2007-10-19 08:13:26 in postgis (timestamp)
anf template ${validity_start_time.value}
<TimeStamp><when>2007-10-19T08:13:00+00:00</when></TimeStamp>
i try the rawValue attribute...
22 oct. 08:32:35 ERROR [freemarker.runtime] -
Expression validity_start_time.rawValue is undefined on line 1, column 3 in time.ftl.
==> ${validity_start_time.rawValue} [on line 1, column 1 in time.ftl]
Java backtrace for programmers:
freemarker.core.InvalidReferenceException: Expression validity_start_time.rawValue is undefined on line 1, column 3 in time.ftl.
        at freemarker.core.TemplateObject.assertNonNull(TemplateObject.java:124)
        at freemarker.core.Expression.getStringValue(Expression.java:118)
        at freemarker.core.Expression.getStringValue(Expression.java:93)
        at freemarker.core.DollarVariable.accept(DollarVariable.java:76)
In fact, i have a time span (begin-end)
so my template conatains 2 references to datetim :
${validity_end_time.value}
I should have :
*<TimeSpan>*
    <begin>2007-10-19T08:13:00+00:00</begin>
    <end>2007-10-19T08:33:00+00:00</end>
*</TimeSpan>*
according to javacode : time.length == 2 ...???
wms/src/main/java/org/vfny/geoserver/wms/responses/map/kml/KMLVectorTransformer.java
         * Encodes a KML TimePrimitive geometry from a feature.
        protected void encodePlacemarkTime(Feature feature) throws IOException {
            try {
                String time = new FeatureTimeTemplate(template).execute(feature);
                if ( time.length == 0 ) {
                    return;
                if ( time.length == 1 ) {
                    String datetime = encodeDateTime(time[0]);
                    if ( datetime != null ) {
                        //timestamp case
                        start("TimeStamp");
                        element("when", datetime );
                        end("TimeStamp");
                else {
                    //timespan case
                    String begin = encodeDateTime(time[0]);
                    String end = encodeDateTime(time[1]);
                    if (!(begin == null && end == null)) {
                        start("TimeSpan");
                        if ( begin != null ) {
                            element("begin", begin);
                        if ( end != null ) {
                            element("end", end);
                        end("TimeSpan");
            } catch (Exception e) {
                throw (IOException) new IOException().initCause(e);
Sébastien Geindre
DPREVI/AERO/DEV
OK for timespan, i should have written template as foloow :
${validity_start_time.value}||${validity_end_time.value}
i should have read the doc more carefully !!
But i still need the seconds...
I should have :
*<TimeSpan>*
*</TimeSpan>*
            try {
                    return;
                        //timestamp case
                        start("TimeStamp");
                        end("TimeStamp");
                else {
                    //timespan case
                        start("TimeSpan");
                        end("TimeSpan");
Sébastien Geindre
DPREVI/AERO/DEV
Hi Sébastien,
I think you will have to use a string format function against the date
to get this to work with the raw value.
${<timstampField>?string("yyyy-MM-ddTHH:mm:ss")}
Try that and let us know how it goes.
Side note: Andrea was right when he stated that the issue here is coming
up because Sébastien is probably using a different locale which is
causing a different default java date format when converting the date to
a string. Which in turn is causing the kml encoder to improperly parse
the date. A better solution may be to force a specific date format when
converting the date to a string, something that is not locale dependent.
seconds...
in time.ftl.
        at
!DSPAM:4007,471c63a5189781137850744!
Justin Deoliveira
Hi Sébastien,
with ${validity_start_time?string("yyyy-MM-ddTHH:mm:ss")} ,
i have the following error :
22 oct. 15:24:57 ERROR [freemarker.runtime] -
Expected number, date, or string. validity_start_time evaluated instead to freemarker.template.SimpleHash on line 1, column 3 in time.ftl.
==> ${validity_start_time?string("yyyy-MM-ddTHH:mm:ss")} [on line 1, column 1 in time.ftl]
freemarker.template.TemplateException: Expected number, date, or string. validity_start_time evaluated instead to freemarker.template.SimpleHash on line 1, column 3 in time.ftl.
with ${validity_start_time.value?string("yyyy-MM-ddTHH:mm:ss")}
22 oct. 15:28:59 ERROR [freemarker.runtime] -
Expected method. validity_start_time.value?string evaluated instead to freemarker.template.SimpleScalar on line 1, column 3 in time.ftl.
==> ${validity_start_time.value?string("yyyy-MM-ddTHH:mm:ss")} [on line 1, column 1 in time.ftl]
freemarker.template.TemplateException: Expected method. validity_start_time.value?string evaluated instead to freemarker.template.SimpleScalar on line 1, column 3 in time.ftl.
        at freemarker.core.TemplateObject.invalidTypeException(TemplateObject.java:135)
with ${validity_start_time.rawValue?string("yyyy-MM-ddTHH:mm:ss")}
the following one :
22 oct. 15:30:26 ERROR [freemarker.runtime] -
==> ${validity_start_time.rawValue?string("yyyy-MM-ddTHH:mm:ss")} [on line 1, column 1 in time.ftl]
        at freemarker.core.TemplateObject.invalidTypeException(TemplateObject.java:134)
maybe that's why seconds disappear...
i 'd like to do some unit test, where should i start ?
Sébastien Geindre
DPREVI/AERO/DEV
