Paulo van Breugel wrote:
I am using the graph function in r.mapcalc. The input is the name of the
map to be converted and a string with XY values, like:
“newmap = graph(map, 1, x1,y1, x2,y2,… xi,yi)”
The second argument (“1”) shouldn’t be there.
Often, X and Y values are available as separate columns or vectors. In
such cases, it would be much easier if X and Y values can be given as
separate vectors, e.g., something like:
“newmap = graph(map, x=x1,x2,x3,x4,…xi, y=y1,y2,y3,y4,…,yi)”
That exact syntax (i.e. with “x=” and “y=” markers) isn’t possible
without fundamentally re-writing r.mapcalc.
However, it would be possible to implement:
newmap = graph(map, x1,x2,x3,x4, y1,y2,y3,y4)
This would boil down to cloning f_graph() in raster/r.mapcalc/xgraph.c
with
#define X(j) (argz[2 + 2 * (j) + 0][i])
#define Y(j) (argz[2 + 2 * (j) + 1][i])
changed to:
#define X(j) (argz[2 + (j) + 0][i])
#define Y(j) (argz[2 + (j) + n][i])
In practice, we’d want to re-factor the common code.
A (untested) patch to implement a graph2() function with the above
syntax is attached.
Index: raster/r.mapcalc/r.mapcalc.html
— raster/r.mapcalc/r.mapcalc.html (revision 53894)
+++ raster/r.mapcalc/r.mapcalc.html (working copy)
@@ -298,6 +298,8 @@
exp(x,y) x to the power y F
float(x) convert x to single-precision floating point F
graph(x,x1,y1[x2,y2…]) convert the x to a y based on points in a graph F
+graph2(x,x1[,x2,…],y1[,y2…])
- alternative form of graph() F
if decision options: *
if(x) 1 if x not zero, 0 otherwise
if(x,a) a if x not zero, 0 otherwise
Index: raster/r.mapcalc/function.c
— raster/r.mapcalc/function.c (revision 53894)
+++ raster/r.mapcalc/function.c (working copy)
@@ -74,6 +74,7 @@
{“nmode”, c_varop, f_nmode},
{“graph”, c_graph, f_graph},
- {“graph2”, c_graph, f_graph2},
{“rand”, c_binop, f_rand},
Index: raster/r.mapcalc/xgraph.c
— raster/r.mapcalc/xgraph.c (revision 53894)
+++ raster/r.mapcalc/xgraph.c (working copy)
@@ -90,6 +90,9 @@
break;
+#undef X
+#undef Y
+#undef x
continue;
@@ -99,3 +102,79 @@
return 0;
+int f_graph2(int argc, const int *argt, void **args)
- DCELL **argz = (DCELL **) args;
- DCELL *res = argz[0];
- int n = (argc - 1) / 2;
- int i, j;
- if (argc < 3)
- return E_ARG_LO;
- if (argc % 2 == 0)
- return E_ARG_NUM;
- if (argt[0] != DCELL_TYPE)
- return E_RES_TYPE;
- for (i = 1; i <= argc; i++)
- if (argt[i] != DCELL_TYPE)
- return E_ARG_TYPE;
- for (i = 0; i < columns; i++) {
+#define X(j) (argz[2 + (j) + 0][i])
+#define Y(j) (argz[2 + (j) + n][i])
+#define x (argz[1][i])
- if (IS_NULL_D(&x))
- goto null;
- for (j = 0; j < n; j++)
- if (IS_NULL_D(&X(j)))
- goto null;
- for (j = 0; j < n - 1; j++)
- if (X(j + 1) <= X(j))
- goto null;
- if (x <= X(0)) {
- if (IS_NULL_D(&Y(0)))
- goto null;
- res[i] = Y(0);
- continue;
- if (x >= X(n - 1)) {
- if (IS_NULL_D(&Y(n - 1)))
- goto null;
- res[i] = Y(n - 1);
- continue;
- for (j = 0; j < n - 1; j++) {
- if (x > X(j + 1))
- continue;
- if (IS_NULL_D(&Y(j)) || IS_NULL_D(&Y(j + 1)))
- goto null;
- res[i] =
- Y(j) + (x - X(j)) * (Y(j + 1) - Y(j)) / (X(j + 1) - X(j));
- break;
+#undef X
+#undef Y
+#undef x
- continue;
- null:
- SET_NULL_D(&res[i]);
- return 0;
Index: raster/r.mapcalc/r3.mapcalc.html
— raster/r.mapcalc/r3.mapcalc.html (revision 53894)
+++ raster/r.mapcalc/r3.mapcalc.html (working copy)
@@ -202,6 +202,8 @@
Index: raster/r.mapcalc/func_proto.h
— raster/r.mapcalc/func_proto.h (revision 53894)
+++ raster/r.mapcalc/func_proto.h (working copy)
@@ -74,6 +74,7 @@
extern args_t c_isnull;
extern func_t f_graph;
+extern func_t f_graph2;
extern args_t c_graph;
extern func_t f_min;
