[GRASS-dev] grass 7.2 planning
Martin, Markus,
evoking projection systems' related tickets, I am wondering if this one
should be considered blocker, given epsg:3857 is quite broadly used:
https://trac.osgeo.org/grass/ticket/2229
Have a nice sunday !
Vincent.
Le dimanche 21 août 2016 à 14:54 +0200, Martin Landa a écrit :
Dear devs,
2016-07-01 0:42 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
> I am afraid that we have delay, I hope that we will have some time to
> work on GRASS during ISPRS in Prague. What about:
> * soft freeze: ~ 15 July
> * hard freeze + RC1: ~ 15 August
> * bug squashing: FOSS4G Bonn
> * RC2: ~ 30 August
> * final: ~ 7 September
I would like to propose slowly to move from SOFT to HARD freeze of
rel72 branch [1]. There is no ticket marked as blocker [2], please
update priority to blocker if you feel that there are tickets which
must be solved before RC1.
Thanks, Martin
[1] https://trac.osgeo.org/grass/wiki/RFC/4_ReleaseProcedure
[2] https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&priority=blocker&priority=critical&milestone=7.2.0&group=type&order=priority
On Fri, May 27, 2016 at 12:02 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Tue, May 24, 2016 at 7:39 PM, Markus Neteler <neteler@osgeo.org> wrote:
- I also created a DRAFT: https://trac.osgeo.org/grass/wiki/Release/7.2.0-News
- important: please add fixes and your favourite improvements to the
7.2.0-News page (too much for one person to check)
Please :slight_smile:
Thanks.
Fixes are added automatically, no ? And they should no go into the "module changes" sections, or ?
As a side note: should we profit of these release announcements to also list all the new addons checked into the repository since the last release ?
Moritz
On Tue, Aug 30, 2016 at 11:08 AM, Moritz Lennert <
If you mean the list of closed tickets, I would say that that's not enough.
It contains all sorts of stuff (and is [fortunately] very long) and the
ticket title often does not tell you enough (or in a right way) about what
was changed. So a hand-crafted note is better, I think.
I think this is a great idea. It might be just hard to say what is "since
the last release" (now we work on 6.4, 7.0 and 7.2 series).
Unfortunately not really:
- many bug report titles are hard to understand
- many fixes do not have a bug report
I believe they should. Because most users will read that part, not the
"scary" #somenumber lines :slight_smile:
Yes. Also, because it is organized by topic, not by ascending numbers.
Yes, sounds great.
    last release ?
"since the last release" (now we work on 6.4, 7.0 and 7.2 series).
For each release news, we would put in the addons added since the last release of that series.
So, for 7.0.5, we would add the grass6 addons which were uploaded since 7.0.4, and for 7.2 a list of all addons since 7.0. I don't think we have to do this for grass6.
Sound ok ?
Moritz
On Wed, Aug 31, 2016 at 2:52 AM, Moritz Lennert <
do this for grass6.
Sound ok ?
Yes. Log for the Makefile from each module type directory could be a
starting point:
https://trac.osgeo.org/grass/log/grass-addons/grass7/raster/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/vector/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/imagery/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/raster3d/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/misc/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/display/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/db/Makefile
https://trac.osgeo.org/grass/log/grass-addons/grass7/temporal/Makefile
    Sound ok ?
starting point:
Good idea.
Although I have a question concerning these Makefiles. I noticed that I never entered i.segment.uspo in
but it is being compiled on the Windows server:
https://wingrass.fsv.cvut.cz/grass73/x86_64/addons/grass-7.3.svn/
What exactly is the role of these Makefiles ? Why do we need them ?
Moritz
On Thu, Sep 1, 2016 at 10:57 AM, Moritz Lennert
The Windows built train does not use the Makefiles (that's only
happening on Unix based system) but simply compiles everything in the
directory tree.
The Linux compile chain for the addons does use the Makefiles: hence
modules should be added there.
directory tree.
You mean for the binary snapshot ? Users on Linux can still run g.extension on a module even if it does not have an entry in the section Makefile...
Here's a preliminary list of the new ones that are listed with 'g.extension -c', but I'll clean that up tomorrow the latest:
v.tin.to.rast: Converts (rasterize) a TIN map into a raster map
v.maxent.swd: Export raster values at given point locations as text file
in SWD format for input in Maxent
v.in.gbif: importing of GBIF species distribution data
v.in.redlist: importing of IUCN Red List Spatial Data
v.class.mlR: Provides supervised support vector machine classification
v.in.natura2000: importing of Natura 2000 spatial data of protected areas
v.mrmr: Perform Minimum Redundancy Maximum Relevance Feature Selection
on a GRASS Attribute Table
v.in.osm: Imports OpenStreetMap data into GRASS GIS.
v.stream.order: Compute the stream order of stream networks stored in a
vector map at specific outlet vector points
r.mcda.promethee: Multicirtieria decision analysis based on PROMETHEE method
r.stream.variables:
r.category.trim: Export categories and corresponding colors as QGIS
colour file or csv file. Non-existing categories and their colour
definitions will be removed.
r.mregression.series:
r.series.decompose: Program calculates decomposition of time series X
r.out.legend: Create and export image file with legend of a raster map
r.terrain.texture: Pit and peak density
r.tri: Terrain Ruggedness Index
r.vector.ruggedness: Vector Ruggedness Measure
r.euro.ecosystem: Sets colors and categories of European ecosystem
raster data set
r.jpdf: From two series of input raster maps, calculates the joint
probability function and outputs the probabilities of occurrence in the
specified bins.
r.neighborhoodmatrix: Calculates a neighborhood matrix for a raster map
with regions
r.change.info: Landscape change assessment
r.randomforest: Provides supervised random forest classification
i.segment.stats: Calculates statistics describing raster areas
i.ortho.corr: Correct orthophoto taking part of the near orthophotos
using the camera angle map
i.segment.uspo: Unsupervised segmentation parameter optimization
i.gcp: Manages Ground Control Points (GCPs) non-interactively.
i.landsat8.swlst: Practical split-window algorithm estimating Land
Surface Temperature from Landsat 8 OLI/TIRS imagery (Du, Chen; Ren,
Huazhong; Qin, Qiming; Meng, Jinjie; Zhao, Shaohua. 2015)
i.lswt: Compute LSWT from TOA Brightness Temperatures
New addons since 7.0.4 (since May):
v.in.pygbif:
v.strds.stats: Calculates univariate statistics from given space-time
raster datasets based on a vector map
v.sort.points: Sorts a vector point map according to a numeric column
v.what.spoly: Queries vector map with overlaping "spaghetti" polygons
(e.g. Landsat footprints) at given location. Polygons must have not
intersected boundaries.
v.explode: "Explode" polylines, splitting them to separate lines (uses
v.split + v.category)
v.clip: Extracts features of input map which overlay features of clip map.
v.surf.tps:
r.colors.matplotlib: Convert or apply a Matplotlib color table to a
GRASS raster map
r.colors.cubehelix: Create or apply a cubehelix color table to a GRASS
raster map
r.object.geometry: Calculates geometry parameters for raster objects.
r3.what: Queries 3D raster in specified 2D or 3D coordinates.
i.landsat8.qc: Reclass Landsat8 QA band according to acceptable pixel
quality as defined by the user
i.fusion.hpf:
i.image.bathymetry: Satellite Derived Bathymetry (SDB) from
multispectral images
m.printws: Opens a workspace file and creates a map sheet according to
its visible contents.
* RC2: ~ 30 August
since 7.0.5 is still not out (should happen soon) I would suggest to
postpone also milestone for G72 - hardfreezing + RC1 ~ 25/9. Feel free
to update blockers [1] (currently no tickets marked as blockers and
critical). Thanks, Ma
[1] https://trac.osgeo.org/grass/query?priority=blocker&priority=critical&status=assigned&status=new&status=reopened&milestone=7.2.0&group=type&order=priority
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, Sep 7, 2016 at 10:03 PM, Martin Landa <landa.martin@gmail.com> wrote:
I would suggest to
Yes, 7.2.0RC1 around 25th of Sept might be good.
Feel free
Let's assign a few :slight_smile: Open issue are here:
https://trac.osgeo.org/grass/query?status=new&status=assigned&status=reopened&milestone=7.2.0&group=type&order=priority
And please all update
the new db.login blocker for solved, thanks.
The question is if we need a new RC or go ahead?
Any objections to go ahead and release without new RC?
2016-09-28 23:20 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
I guess you are referring to 7.0.5 (this thread is about 7.2).
Regarding 7.0.5 I would go ahead without any new RC2. Martin
Martin Landa
Sorry for the mixup.
So, we should also go on with 7.2 and target a soonish release.
Yet open issue are here, some will be postponed to 7.2.1…:
2016-09-13 17:38 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
+1 for 7.2.0RC1 in the next days. Any objections, comments? Ma
Martin Landa
On Sun, Oct 2, 2016 at 5:16 PM, Martin Landa <landa.martin@gmail.com> wrote:
no objections, but let's get 7.0.5 out first
Anna
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
2016-10-03 4:09 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
right, 7.0.5 has been release yesterday (2/10) [1]. Ma
[1] https://trac.osgeo.org/grass/wiki/Release/7.0.5-News
Martin Landa
On Sun, Oct 2, 2016 at 11:16 PM, Martin Landa <landa.martin@gmail.com> wrote:
Are there objections to get RC1 out? Here nothing is listed:
https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.2.0tobebackported
All open issue:
To be completed:
2016-10-22 15:53 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
no objections, +1 for 7.2.0RC1...
To be completed:
Also call for nice screenshots of the functionality (I have already
added wxGUI data catalog). Martin
Martin Landa
