[GRASS-dev] [GRASS GIS] #995: WxGUI startup screen fails if GISDBASE path contains non-latin characters
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: wxgui, windows | Platform: MSWindows Vista
      Cpu: Unspecified |
WXGUI startup screen goes bad when GISDBASE is pointing to folder with
non-latin chars in path.
Steps to reproduce: "mkdir 'Šaursliežu dzelzceļš'" and set it as GISDBASE.
Error in command execution g.gisenv
Execution failed: 'g.gisenv
set=GISDBASE=C:/Users/Maris/Documents/Šaursliežu dzelzceļš'
Details:
Error: Unable to exectute command: 'g.gisenv
OK
KŽ█DA:G_getenv(): Variable LOCATION_NAME not set
Exception in thread Thread-1:
   File "C:\OSGeo4W\apps\Python25\lib\threading.py", line 486, in
__bootstrap_inn
er
     self.run()
   File "C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\gcmd.py",
line 52
7, in run
     shell=sys.platform=="win32")
   File "C:\Program Files\GRASS-64-SVN\Python25\lib\subprocess.py", line
594, in
__init__
     errread, errwrite)
816, in
_execute_child
     startupinfo)
UnicodeEncodeError: 'ascii' codec can't encode character u'\u0160' in
position 9
2: ordinal not in range(128)
Exception in thread Thread-2:
__bootstrap_inn
er
     self.run()
line 52
7, in run
594, in
__init__
     errread, errwrite)
816, in
_execute_child
     startupinfo)
position 7
9: ordinal not in range(128)
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 854,
in <mo
dule>
     GRASSStartUp = StartUp(0)
   File "C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-
unicode\wx\_core.p
y", line 7935, in __init__
unicode\wx\_core.p
y", line 7509, in _BootstrapApp
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 825,
in OnI
nit
     StartUp = GRASSStartup()
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 165,
in __i
nit__
     self._set_properties()
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 206,
in _se
t_properties
     self.OnSetDatabase(None)
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 665,
in OnS
etDatabase
     self.OnSelectLocation(None)
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 617,
in OnS
electLocation
     self.listOfLocations[self.lblocations.GetSelection()]))
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 591,
in Upd
ateMapsets
     "set=GISDBASE=%s" % self.gisdbase])
line 35
7, in __init__
     _("Error: ") + self.GetError()))
gui_modules.gcmd.CmdError
Also interesting bit - I DON'T have such folder as "C:\OSGeo4W"
Setting this as a blocker because it's impossible to change bogous
GISDBASE value as WXGUI startup screen fails to come up and provide
GISDBASE choice option. Only solution is to start GRASS CLI or rm any
.grass* files. Both options are not beginner-friendly.
Another part in location wizard:
access: No such file or directory
KŽ█DA:ATRAąAN┬S VIETA << C:\Users\Maris\Documents\atstar pem/mans >> nav
       pieejama
SVN\etc\wxpython\gui_modules\location_wizard.p
y", line 1710, in OnEnterPage
     self.ldatabase.SetLabel(str(database))
position 2
5: ordinal not in range(128)
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 412,
in OnW
izard
     grassdatabase = self.tgisdbase.GetValue())
y", line 1853, in __init__
     msg = self.OnWizFinished()
y", line 2011, in OnWizFinished
     set='GISDBASE=%s' % database)
line 59
6, in RunCommand
     ps = grass.start_command(prog, flags, overwrite, quiet, verbose,
**kwargs)
   File "C:\Program Files\GRASS-64-SVN\etc\python\grass\script\core.py",
line 143
, in start_command
     args = make_command(prog, flags, overwrite, quiet, verbose, **options)
line 106
, in make_command
     args.append("%s=%s" % (opt, _make_val(val)))
line 73,
  in _make_val
     return str(val)
position 3
4: ordinal not in range(128)
WinGRASS-6.4.SVN-r41363-1 running Windows Vista.
Ticket URL: <http://trac.osgeo.org/grass/ticket/995&gt;
Resolution: | Keywords: wxgrass, i18n
  Platform: MSWindows Vista | Cpu: Unspecified
Changes (by martinl):
  * keywords: wxgui, windows => wxgrass, i18n
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:1&gt;
Resolution: | Keywords: wingrass, i18n
  * keywords: wxgrass, i18n => wingrass, i18n
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:2&gt;
  Reporter: marisn | Owner: martinl
      Type: defect | Status: assigned
* cc: grass-dev@lists.osgeo.org (added)
  * owner: grass-dev@lists.osgeo.org => martinl
  * status: new => assigned
Comment:
Hopefully fixed r41390. Commands execution is affected, so please test on
different platforms with various locales. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:3&gt;
Comment (by marisn):
I will test on windows in some days. Seems fine on Linux, still it's
impossible to create location within such GISDBASE with location wizard.
If location exists, it's possible to use it.
   File "/home/maris/soft/grass_64/dist.x86_64-unknown-linux-
gnu/etc/wxpython/gui_modules/location_wizard.py", line 1712, in
OnEnterPage
position 23: ordinal not in range(128)
gnu/etc/wxpython/gis_set.py", line 412, in OnWizard
gnu/etc/wxpython/gui_modules/location_wizard.py", line 1855, in __init__
gnu/etc/wxpython/gui_modules/location_wizard.py", line 2013, in
OnWizFinished
gnu/etc/wxpython/gui_modules/gcmd.py", line 596, in RunCommand
**kwargs)
gnu/etc/python/grass/script/core.py", line 143, in start_command
gnu/etc/python/grass/script/core.py", line 106, in make_command
gnu/etc/python/grass/script/core.py", line 73, in _make_val
     return str(val)
position 32: ordinal not in range(128)
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:4&gt;
Comment (by martinl):
Replying to [comment:4 marisn]:
OnEnterPage
Please try r41393.
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:5&gt;
That's it! Now also location wizard works just fine with "šaursliežu
dzelzceļš" :slight_smile: Will perform tests on Windows Vista within this weekend.
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:6&gt;
Location Wizard still fails in Windows Vista WinGRASS-6.4.SVN-r41428-1:
SVN\etc\wxpython\gui_modules\location_wizard.py:2002:
UnicodeWarning: Unicode unequal comparison failed to convert both
arguments to U
nicode - interpreting them as being unequal
   if current_gdb != database:
   File "C:/Program Files/GRASS-64-SVN/etc/wxpython/gis_set.py", line 418,
in OnW
izard
line 60
8, in RunCommand
**kwargs)
   File "c:/osgeo4w/usr/src/grass64_release/dist.i686-pc-
mingw32\etc\python\grass
\script\core.py", line 145, in start_command
\script\core.py", line 52, in __init__
594, in
__init__
     errread, errwrite)
816, in
_execute_child
     startupinfo)
position 7
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:7&gt;
Location Wizard still fails on Vista WinGRASS-6.4.SVN-r41749-1
in OnW
izard
   File "c:\osgeo4w\usr\src\grass64_release\dist.i686-pc-
mingw32\etc\wxpython\gui
_modules\location_wizard.py", line 1853, in __init__
_modules\location_wizard.py", line 2011, in OnWizFinished
line 60
9, in RunCommand
**kwargs)
594, in
__init__
     errread, errwrite)
816, in
_execute_child
     startupinfo)
UnicodeEncodeError: 'ascii' codec can't encode character u'\u0161' in
position 7
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:8&gt;
  Priority: critical | Milestone: 6.4.0
  * priority: blocker => critical
Comment:
I am changing priority of this bug to critical. wxGUI is not default GUI
in GRASS 6.4., so wxGUI-related bugs are not blockers for this version.
Ticket URL: <https://trac.osgeo.org/grass/ticket/995#comment:9&gt;
Keywords: wingrass, i18n | Platform: MSWindows Vista
      Cpu: Unspecified |
Comment(by neteler):
Is this still an issue in 6.4.svn?
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:10&gt;
      Cpu: Unspecified |
See also trac #1004
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:11&gt;
Priority: critical | Milestone: 6.4.2
      Cpu: Unspecified |
Changes (by hellik):
  * milestone: 6.4.0 => 6.4.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:12&gt;
      Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:12 hellik]:
Don't forget to put a big, fat warning that WinGRASS works only for users
with names without non-latin letters. Users migh have no write permission
outside their home direcories and thus be unable to start GRASS at all.
As nightly WinGRASS server is down, I can't test SVN, but RC1 is still
unable to start at all. I can't set GRASSDBASE to anything, as wxgui is
failing before first screen. Still it's possible, that it's caused by
#1286
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:13&gt;
      Cpu: Unspecified |
Comment(by marisn):
Trying to launch GRASS 6.4 on a fresh install causes python to crash.
Windows Vista 32bit.
WinGRASS-6.4.SVN-r47993-1-Setup.exe
Output I got by running GRASS from CMD:
C:\Program Files\GRASS 6.4.SVN>grass64svn.bat
   File "C:/Program Files/GRASS 6.4.SVN/etc/wxpython/gis_set.py", line 863,
in <m
odule>
   File "c:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-
unicode\wx\_core.p
unicode\wx\_core.p
   File "C:/Program Files/GRASS 6.4.SVN/etc/wxpython/gis_set.py", line 834,
in On
Init
   File "C:/Program Files/GRASS 6.4.SVN/etc/wxpython/gis_set.py", line 166,
in __
init__
   File "C:/Program Files/GRASS 6.4.SVN/etc/wxpython/gis_set.py", line 216,
in _s
et_properties
     not os.path.isdir(os.path.join(self.gisdbase, location)):
   File "C:\Program Files\GRASS 6.4.SVN\Python25\lib\ntpath.py", line 67,
in join
     elif isabs(b):
   File "C:\Program Files\GRASS 6.4.SVN\Python25\lib\ntpath.py", line 53,
in isab
s
     s = splitdrive(s)[1]
   File "C:\Program Files\GRASS 6.4.SVN\Python25\lib\ntpath.py", line 119,
in spl
itdrive
     if p[1:2] == ':':
TypeError: 'NoneType' object is unsubscriptable
Here's .grassrc6 file contents it creates:
GISDBASE: C:/Users/Māris
LOCATION_NAME: <UNKNOWN>
MAPSET: <UNKNOWN>
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:14&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:13 marisn]:
it's not down, see [1].
[1] http://lists.osgeo.org/pipermail/grass-dev/2011-September/055659.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:15&gt;
      Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:15 martinl]:
Just for the record - it was down at that time:
http://lists.osgeo.org/pipermail/grass-user/2011-March/059866.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:16&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Where are we at on this issue ? I have several students and colleagues who
have been trying to use GRASS on Windows (Vista and 7) and have failed
because their username contains non-latin characters.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:17&gt;
Priority: critical | Milestone: 7.0.0
      Cpu: Unspecified |
Changes (by marisn):
  * milestone: 6.4.2 => 7.0.0
Comment:
Stuck forever with 6.x releases. There is no way how to fix this issue for
6.x. Only hope is to move away from anything shell related in 7.x and thus
avoid any OEM codepage issues on Windows.
Solution for end-users: create a new user with only latin letters in it's
name for GRASS usage.
See more here:
http://lists.osgeo.org/pipermail/grass-dev/2011-March/053874.html
Replying to [comment:17 mlennert]:
who have been trying to use GRASS on Windows (Vista and 7) and have failed
> Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:18&gt;
      Cpu: Unspecified |
Any news on this issue, at least for GRASS 7 ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/995#comment:19&gt;
