[GRASS-dev] point cloud analysis: new features
a new spatial index for point data is available in lib/btree2: a
multidimensional search tree, also known as k-d tree.
What is it good for:
- nearest neighbor statistics: test if points are randomly
distributed. The current GRASS addon v.nnstat uses an external k-d
tree from PCL (which in turn uses flann) which finds the approximate,
not the exact nearest neighbor. The new GRASS-native k-d tree always
finds the real nearest neighbor.
- spatial cluster analysis: a point cloud can be partitioned into
separate clusters where points within each cluster are closer to each
other than to points of another cluster. To be implemented.
- point cloud thinning: a sample can be generated from a large point
cloud by specifying a minimum distance between sample points. To be
implemented.
The new k-d tree is now used by v.clean tool=snap (Vect_snap_lines()),
reducing both memory consumption and processing time.
More technical:
the new k-d tree finds the exact nearest neighbor(s), not some
approximation. It supports up to 255 dimensions. It is dynamic, i.e.
points can be inserted and removed at any time. It is balanced to
improve search performance. It provides k nearest neighbor search
(find k neighbors to a given coordinate) as well as radius or distance
search (find all neighbors within radius, i.e. not farther away than
radius to a given coordinate).
Markus M
Great! The spatial cluster analysis option would be really good, e.g. for model evaluation using spatially segregated k-fold cross validation methods.
On 1 January 2015 22:18:39 CET, Markus Metz markus.metz.giswork@gmail.com wrote:
implemented.
More technical:
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
[http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)
Sent from my Android device with K-9 Mail. Please excuse my brevity.
Hi Markus,
On 01/01/15 22:18, Markus Metz wrote:
Excellent news.
I suggest implementing DBSCAN: http://en.wikipedia.org/wiki/DBSCAN
It is density-based and thus produces more useful results than
centroid-based methods (k-means and relatives). It can actually
trace the shapes of spatial clusters (even concave ones) and does
not require a priori knowledge about the number of clusters. It
can also handle noise.
There is a reference implementation (albeit in Java) that you can
use to compare it with other clustering algorithms:
  http://elki.dbs.ifi.lmu.de/
An implementation in C (that I have not tried) is here:
  https://github.com/siddharth950/DBSCAN
The one drawback of DBSCAN is that it needs an efficient spatial
index to perform well -- and you have just taken care of that!
implemented.
I would also like to point out that SAGA GIS is moving into
the same direction, i.e. more efficient processing of very
large point clouds. The latest release includes a number
of new point cloud tools. Perhaps it's worth a look.
Most importantly, SAGA GIS has introduced a new file format,
the SAGA Pointcloud (.spc) format. It is compact and yet
flexible enough for a variety of purposes. I recommend to
consider implementing import/export of this format in GRASS 7,
preferably not via v.in.ogr, to avoid the OGR model conversion
overhead.
If you think this would be an interesting option, then you can
find a summary on our tracker:
  http://gvsigce.sourceforge.net/mantis/view.php?id=595
(we are going to implement ".spc" in gvSIG CE, as well).
Best wishes,
Ben
More technical:
Markus M
Dr. Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
Spatial technology for the masses, not the classes:
experience free and open source GIS at http://gvsigce.org
On Fri, Jan 2, 2015 at 10:08 AM, Benjamin Ducke <benducke@fastmail.fm> wrote:
Hi Markus,
Excellent news.
Done in trunk r63952 as v.cluster. It is not a GRASS7 addon because it
does not work with G7.0. At the moment it only identifies and labels
clusters. Connectivity graphs and cluster shapes are not implemented.
In future, I would like to add OPTICS because OPTICS can better handle
different clusters with different densities.
Markus M
implemented.
overhead.
Best wishes,
Ben
More technical:
Markus M
Dr. Benjamin Ducke
{*} GIS Developer
Tried it out, and it works like a charm, great!
One question/request, would it be terribly difficult to add an option to compute an user-defined number of clusters of equal size?
On Sun, Jan 4, 2015 at 9:02 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hi Markus,
Excellent news.
  • nearest neighbor statistics: test if points are randomly
  • spatial cluster analysis: a point cloud can be partitioned into
Markus M
index to perform well – and you have just taken care of that!
  • point cloud thinning: a sample can be generated from a large point
    implemented.
of new point cloud tools. Perhaps it’s worth a look.
overhead.
(we are going to implement “.spc” in gvSIG CE, as well).
Best wishes,
Ben
More technical:
Markus M
Dr. Benjamin Ducke
{} Geospatial Consultant
} GIS Developer
I think you are looking for a completely different algorithm
there. There are many clustering methods that will produce
exactly k clusters. But what do you mean by size: number of
points per cluster or spatial extent/area?
In both cases, I am not sure how you would reconcile the
two opposing goals: (A) find the actual cluster shapes,
(B) make the cluster shapes so that all clusters are of
equal size.
(please see also my comment to Markus below).
<markus.metz.giswork@gmail.com <mailto:markus.metz.giswork@gmail.com>>
Thanks Markus, this is excellent progress.
It seems to me that the approximation of cluster shapes from grouped
points is a generic problem that would best be solved with a separate
module. As long as the shapes are roughly convex, the existing v.hull
should work fine. For concave shapes, AFAIK things become messy because
common methods such as alpha shapes require the user to provide
threshold values.
Ben
    Markus M
    > There is a reference implementation (albeit in Java) that you can
    > use to compare it with other clustering algorithms:
    > http://elki.dbs.ifi.lmu.de/
    > An implementation in C (that I have not tried) is here:
    > https://github.com/siddharth950/DBSCAN
    > The one drawback of DBSCAN is that it needs an efficient spatial
    > index to perform well -- and you have just taken care of that!
    >> - point cloud thinning: a sample can be generated from a large point
    >> cloud by specifying a minimum distance between sample points. To be
    >> implemented.
    >> The new k-d tree is now used by v.clean tool=snap
    >> reducing both memory consumption and processing time.
    > I would also like to point out that SAGA GIS is moving into
    > the same direction, i.e. more efficient processing of very
    > large point clouds. The latest release includes a number
    > of new point cloud tools. Perhaps it's worth a look.
    > Most importantly, SAGA GIS has introduced a new file format,
    > the SAGA Pointcloud (.spc) format. It is compact and yet
    > flexible enough for a variety of purposes. I recommend to
    > consider implementing import/export of this format in GRASS 7,
    > preferably not via v.in.ogr, to avoid the OGR model conversion
    > overhead.
    > If you think this would be an interesting option, then you can
    > find a summary on our tracker:
    > http://gvsigce.sourceforge.net/mantis/view.php?id=595
    > (we are going to implement ".spc" in gvSIG CE, as well).
    > Best wishes,
    > Ben
    >> More technical:
    >> the new k-d tree finds the exact nearest neighbor(s), not some
    >> approximation. It supports up to 255 dimensions. It is dynamic, i.e.
    >> points can be inserted and removed at any time. It is balanced to
    >> improve search performance. It provides k nearest neighbor search
    >> (find k neighbors to a given coordinate) as well as radius or
    distance
    >> search (find all neighbors within radius, i.e. not farther away than
    >> radius to a given coordinate).
    >> Markus M
    >> _______________________________________________
    >> grass-dev mailing list
    >> grass-dev@lists.osgeo.org <mailto:grass-dev@lists.osgeo.org>
    >> http://lists.osgeo.org/mailman/listinfo/grass-dev
    > Dr. Benjamin Ducke
    > {*} Geospatial Consultant
    > {*} GIS Developer
    > Spatial technology for the masses, not the classes:
    > experience free and open source GIS at http://gvsigce.org
Dr. Benjamin Ducke
{*} GIS Developer
On Mon, Jan 5, 2015 at 12:17 PM, Benjamin Ducke <benducke@fastmail.fm>
Yes, I was looking at something similar to what the function stratify in
the R spcosa package does: "Methods for partitioning a spatial object into
compact strata by means of k-means. The objective function to minimize is
the mean squared shortest distance (MSSD). Optionally, the strata may be
forced to be of equal size. This facilitates field work in case of
stratified simple random sampling for composites". The key here is to
create as compact strata as possible, optionally of equal size (number of
points per cluster).
equal size.
it
handle
threshold values.
Ben
> Markus M
point
be
> >> implemented.
> > overhead.
> > Best wishes,
> > Ben
> >> More technical:
i.e.
> distance
than
> >> Markus M
> > Dr. Benjamin Ducke
> > {*} GIS Developer
Dr. Benjamin Ducke
{*} GIS Developer
On Mon, Jan 5, 2015 at 12:17 PM, Benjamin Ducke <benducke@fastmail.fm> wrote:
threshold values.
This is true, but v.concave.hull [0] could help :wink:
Markus M
[0] https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.concave.hull
As of r64017, the available clustering methods are
dbscan,dbscan2,density,optics,optics2. I hope the documentation is
clear enough.
Markus M
threshold values.
All these great addons !
For this particular one: would it be interesting / possible to integrate it directly into v.hull ?
Moritz
threshold values.
Markus M
Wow. And it's been there for a while. How could I not see that?
I think it's high time that I switch from GRASS 6 to 7.
Nevertheless, since you did all that work on v.cluster in GRASS 6,
maybe it would be worth implementing this:
http://grasswiki.osgeo.org/wiki/Create_concave_hull
... in a GRASS 6 shell script?
I am looking forward to trying the new clustering algorithms,
especially "density" and "optics2"
Many thanks,
Ben
Dr. Benjamin Ducke
{*} GIS Developer
On Fri, Jan 9, 2015 at 9:35 AM, Moritz Lennert
threshold values.
No, because v.hull is a C module and v.concave.hull a script which
does not use v.hull at all. Instead, v.concave.hull cleans the output
of v.delaunay to create concave hulls.
Markus M
On Fri, Jan 9, 2015 at 11:45 AM, Benjamin Ducke <benducke@fastmail.fm> wrote:
threshold values.
Markus M
Indeed.
v.cluster exists only in GRASS 7.1. It can not even be backported ti
GRASS 7.0 because it relies on a new (new to GRASS) spatial index that
is only available in GRASS 7.1.
If you know Python and shell scripting, translating v.concave.hull to
a shell script is easy. Otherwise, chances are good that the Python
script v.concave.hull also runs with GRASS 6. Maybe some option names
need to be modified.
Markus M
Many thanks,
Ben
Dr. Benjamin Ducke
{*} GIS Developer
On Sun, Jan 11, 2015 at 9:03 PM, Markus Metz
threshold values.
I have a similar problem: imagine a set of contour lines which
describe the bathymetry of a lake, so essentially contour lines which
are closing a polygon but consist of different lines.
I would like to get the respective polygon representation, i.e. the
outer lines only and those turned into a polygon.
I just tried v.concave.hull on it, however, it expects points and not lines.
Does anyone have an idea how to achieve that?
thanks
markusN
Hei Markus,
Not sure I fully understood you problem...
I guess you don`t have a "grouping variable" (e.g. a lake ID) for the contour lines? If you had one, you could probably extract the outer lines based on the attribute table (get max depth by lake (or min depth, depending on how it is coded), something like where="depth=max_depth") and turn them into polygon (if lines are properly closed).
Otherwise, if contour lines are not grouped by lake, personally I might have probably used PostGIS like this:
1) Polygonize all contour lines (ST_MakePolygon), eventually after checking if line strings are properly closed (ST_IsClosed)
2) SELECT all intersecting combinations of polygons in the resulting table (ST_Intersects)
3) LEFT JOIN polygonised contour lines with themselves using ST_CoveredBy
4) SELECT only those where left join IS NULL
Is that somehow in the direction you were thinking?
Stefan
Von: grass-dev-bounces@lists.osgeo.org <grass-dev-bounces@lists.osgeo.org> im Auftrag von Markus Neteler <neteler@osgeo.org>
thanks
markusN
threshold values.
I'm not sure I completely understand the situation, maybe an image would help.
I take it that there are no attributes (e.g. depth) linked to the lines ?
Otherwise, maybe v.to.points + v.concave.hull + v.select ?
Or, manually, using the new "Select vector feature(s)" tool in the Map Display ?
Moritz
ok, to make it hopefully clear:
attached a screenshot of the lines describing contours of a lake.
I would like to turn this into a polygon describing the like, ideally
in a non-manual way.
thanks
(attachments)
Hei Markus,
Assuming you have no attributes for those lines, what about the following procedure:
1) Turning all to closed line strings into areas in a first step (v.centroids) and then
2) use some v.to.db ("sides" option) in order to distinguish inner and outer boundaries, in other words those which have no category at one side from those which have a category at both sides?
3) Then you can extract the latter and build areas only from them...
Stefan
-----Original Message-----
From: grass-dev-bounces@lists.osgeo.org [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Markus Neteler
Sent: 23. mars 2015 12:17
To: Moritz Lennert
Cc: GRASS developers list; Markus Metz
Subject: Re: [GRASS-dev] integrate v.concave.hull into v.hull [was point cloud analysis: new features]]
I would like to turn this into a polygon describing the like, ideally in a non-manual way.
thanks
