[GRASS-dev] Segmentation fault (core dumped) when using r.mapcalc in GRASS 7.0
When using the graph operator in r.mapcalc and when using many points (+500) to define the graph, I am getting a ‘Segmentation fault (core dumped)’. This is shown after the calculation has (apparently) finished.
100%
GRASS 7.0.svn (latlon):~ >
It is difficult to really check whether the whole calculation has been carried out correctly, but the new layer looks OK. I did notice that in the meta data (r.info) of the new layer, only the statement ‘generated by r.mapcalc’ is given, while normally the whole r.mapcalc statement would be shown. Could that be related to the segmentation fault message?
Best regards
Paulo
(+500) to define the graph, I am getting a 'Segmentation fault (core
dumped)'. This is shown after the calculation has (apparently) finished.
100%
meta data (r.info) of the new layer, only the statement 'generated by
r.mapcalc' is given, while normally the whole r.mapcalc statement would be
The expression is added to the history as a comment. The code which
formats the expression had a fixed-sized buffer of 1024 arguments, so
512 or more x,y pairs would overflow it.
This should be fixed in r52725.
On Sat, Aug 18, 2012 at 8:03 PM, Glynn Clements
100%
Paulo sent me the formula, I have tried it, fix confirmed, working now.
Backported to 6.4 and 6.5 in r52726 and r52727.
Hi Markus
I can also confirm it works in the in GRASS 7.0 r52727
Thanks a lot for this quick fix!
Paulo
100%
