I am trying to create a hillshading effect using DEM rasters similar to ESRI multidirectional hillshading, but I am unable to get anything in. grass to perform as good as ESRI (or even gdaldem multidirectional shading).
I am hoping someone in this group has some scripts /addon/tips that I can try.
So far I have tried the following on a few DEMs ( from 3m to 100 m grid sizes).
gdaldem multidirectional hillshading : It’s not grass based, but so far has performed better than other grass options : with the parameter zfactor between 1 and 10. But it does not seem to be quite as good as ESRI.
Other variants of hillshading like r.skyview : Tried with several parameters but it seems to be inferior to gdaldem (It seems to be a ‘washed out’ version of the multidirectional. hillshading).
On Fri, Feb 16, 2024 at 11:20 PM B H via grass-user
<grass-user@lists.osgeo.org> wrote:
1) gdaldem multidirectional hillshading : It's not grass based, but so far has performed better than other grass options : with the parameter zfactor between 1 and 10. But it does not seem to be quite as good as ESRI.
2) Following code is based on some old discussion on this email list.(Its seems to exaggerate the hills and valleys more than I would expect) https://gist.github.com/amcox/b54d65f08fe4448840462901fd6350d4
3) Other variants of hillshading like r.skyview : Tried with several parameters but it seems to be inferior to gdaldem (It seems to be a 'washed out' version of the multidirectional. hillshading).
