I have to calculate the percentage of given class of a raster within the polygons given in a vector (a regular grid). Since I’m dealing with large files and operations repeated in a chain, i should be focusing on what is the optimal (fastest) option to do that. I could vectorize the raster and use v.overlay and v.to.db, or using v.rast.stats i can count out the number of cells (should i use number for that or sum?) and then divide per area of the grid. Any better idea?
Thank you in advance
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
I haven’t tested it, but the fastest way could be to rasterize your polygon layer (using the resolution of the input raster or higher resolution - make sure to assign an unique id to each grid cell before) and then use r.stats
r.stats -a -p input=rasterized_polygon,raster
Rgds,
Paulo
On Wed, Feb 11, 2015 at 12:15 PM, Margherita Di Leo <diregola@gmail.com> wrote:
Best regards,
Via Fermi, 2749
how about,
v.rast.stats with number/sum option and then field calculations?
regards,
sotiris
On 02/11/2015 01:15 PM, Margherita Di Leo wrote:
polygons given in a vector (a regular grid). Since I'm dealing with large
