Is there an (easy) way to upload raster category labels to a point file, equivalent to uploading category values with v.what.rast?
That would be a nice addition to v.what.rast. Probably worth an enhancement ticket in trac.
One workaround would be something like this:
g.copy vect=schools_wake,myschools
v.db.addcolumn myschools col="geolcat int"
v.db.addcolumn myschools col="geollabel varchar(4)"
v.what.rast myschools raster=geology_30m column=geolcat
and then a small Python script :
catlabels=grass.read_command('r.category', map='geology_30m').splitlines()
for catlabel in catlabels:
cat=catlabel.split('\t')[0]
label=catlabel.split('\t')[1]
where='geolcat='+cat
grass.run_command('v.db.update', map='myschools', column='geol_code', value=label, where=where
Moritz
