#3104: geoserver-users SF mailman to discourse?
Reporter: jive | Owner: sac-tickets@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2024-II
Component: SysAdmin | Resolution:
Keywords: |
Comment (by cvvergara):
I tried the import, basically getting errors on all mails
Short version:
Failed to index message in /shared/import/data/geoserver-users/geoserver-
users.mbox at lines 33-1899
users.mbox at lines 1900-1953
users.mbox at lines 1954-2056
users.mbox at lines 2057-2118
users.mbox at lines 2119-2220
The error between each "Failed to index"
undefined method `sub' for :from:Symbol
["/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:91:in
`block in index_emails'",
"/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:158:in
`block (2 levels) in all_messages'", "/
var/www/discourse/script/import_scripts/mbox/support/indexer.rb:190:in
`block in each_mail'",
"/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:210:in
`block in each_line'", "/var/www/discourse/s
cript/import_scripts/mbox/support/indexer.rb:210:in `each_line'",
`each_line'", "/var/www/discourse/script/import_scripts/mbox/support/ind
exer.rb:187:in `each_mail'",
"/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:150:in
`block in all_messages'",
"/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:143:in
`foreach'"
, "/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:143:in
`all_messages'",
"/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:67:in
`index_emails'", "/var/www/discourse/script/imp
ort_scripts/mbox/support/indexer.rb:25:in `block in execute'",
"/var/www/discourse/script/import_scripts/mbox/support/indexer.rb:22:in
`each'",
2:in `execute'",
"/var/www/discourse/script/import_scripts/mbox/importer.rb:43:in
`index_messages'",
"/var/www/discourse/script/import_scripts/mbox/importer.rb:27:in
`execute'", "/var/www/discourse/script/import
_scripts/base.rb:47:in `perform'", "script/import_scripts/mbox.rb:13:in
`<module:Mbox>'", "script/import_scripts/mbox.rb:11:in
`<module:ImportScripts>'", "script/import_scripts/mbox.rb:10:in `<main>'"]
Example problematic header:
From aurelio@...3... Mon Jan 19 10:58:27 2004
Message-ID: <001f01c3dec6$d49f0cb0$6801a8c0@...4...>
From: =?iso-8859-1?Q?Aur=E9lio_Calegari?= <aurelio@...3...>
To: <geoserver-users@lists.sourceforge.net>
Date: Mon, 19 Jan 2004 17:00:04 -0300
MIME-Version: 1.0
An example of a header on an osgeo mailinglist
From
sentto-3377054-1-991426944-postgis=postgis.refractions.net@returns.onelist.com
Fri Jun 1 13:22:16 2001
Return-Path:
<sentto-3377054-1-991426944-postgis=postgis.refractions.net@returns.onelist.com>
Delivered-To: postgis@offsite.refractions.net
Received: from fj.egroups.com (fj.egroups.com [64.211.240.231])
by offsite.refractions.net (Postfix) with SMTP id 4C17A43490
for <postgis@postgis.refractions.net>; Fri, 1 Jun 2001 13:22:15
-0700 (PDT)
X-eGroups-Return:
Probably the `aurelio@...3...`
Doing a `grep '^From ' geoserver-users.mbox`
From andrea.aime@...84... Fri Sep 27 19:40:34 2013
From mihail12@...84... Sun Sep 29 17:34:14 2013
From peter.vonminden@...2631... Mon Sep 30 02:45:30 2013
From andrea.aime@...84... Mon Sep 30 06:13:50 2013
From maurobartolomeoli@...84... Mon Sep 30 07:02:51 2013
From paulius@...4984... Mon Sep 30 07:36:57 2013
From alessio.fabiani@...84... Mon Sep 30 07:44:47 2013
From paulius@...4984... Mon Sep 30 08:01:16 2013
From andrea.aime@...84... Mon Sep 30 08:09:38 2013
Ticket URL: <#3104 (geoserver-users SF mailman to discourse?) – OSGeo;
OSGeo <Gter - OSGeo;
