in the last couple of days, sometime, I get some local build failures due to a bad gateway error returned by osgeo repository.
This morning, a GeoServer PR is failing on most part of the checks due to the same error:
For example:
Error: 9,364 [ERROR] Failed to read artifact descriptor for org.geotools:gt-imagepyramid:jar:35-SNAPSHOT
Error: 9,364 [ERROR] Caused by: The following artifacts could not be resolved: org.geotools:gt-imagepyramid:pom:35-SNAPSHOT (absent): Could not transfer artifact org.geotools:gt-imagepyramid:pom:35-SNAPSHOT from/to osgeo-snapshots (
): status code: 502, reason phrase: Bad Gateway (502)
Error: 9,364 [ERROR] Failed to read artifact descriptor for org.geotools:gt-iau-wkt:jar:35-SNAPSHOT
Error: 9,364 [ERROR] Caused by: The following artifacts could not be resolved: org.geotools:gt-iau-wkt:pom:35-SNAPSHOT (absent): Could not transfer artifact org.geotools:gt-iau-wkt:pom:35-SNAPSHOT from/to osgeo-snapshots (https://repo.osgeo.org/repository/snapshot/): status code: 502, reason phrase: Bad Gateway (502)
Do you have any idea about that?
I see this message being posted a few days ago:
Could that be related?
Please let me know if you have any clue.
Regards, Daniele
