#2678: old-adhoc planned shutdown
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Keywords:
I think most things have been moved off of old-adhoc.
Given it's age, I'd like to just shut it down or at very least turn off
the apache service before the beginning of the new year
Things that have already been moved off it are:
demo.mapserver.org
demo.pycsw.org
Things that are still running
#when I check this it's actually running on 208.218.69.159.clients.your-
server.de (159.69.218.208) - so I shut it off
demo.geohealthcheck.org
demo.pywps.org #looks like this was never resetup as not reachable from
outside (so I shut it off), I suspect it should live with demo.pycsw.org
which has a nice dedicated new pycsw or similar container setup
#I shut down
dev.geohealtcheck.org #no dns so shut down
This I left, but I suspect it is an orphaned sites
oam.osgeo.org (I suspect this is an abandoned site)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: Sysadmin Contract 2022-I => Sysadmin Contract 2022-II
Comment:
Done
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:2>
Keywords: |
Comment (by robe):
Steps involved:
shutdown old-adhoc container
Remove from /etc/nginx/sites-enabled the adhoc.osgeo.org config.
Note on wiki - https://wiki.osgeo.org/wiki/AdhocVM and
https://wiki.osgeo.org/wiki/SAC_Service_Status#old-adhoc
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:3>
Keywords: |
Comment (by strk):
It looks like there was a left-over entry in nginx: #2714
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:4>
Keywords: |
Comment (by strk):
Was the demo.mapserver.org service moved elsewhere ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:5>
Keywords: |
Comment (by Jeff McKenna):
Replying to [comment:5 strk]:
Yes, see https://wiki.osgeo.org/wiki/MapServer_at_osgeo7 (it was a ton of
effort, but important)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:6>
Keywords: |
Comment (by strk):
The nginx configuration for demo.mapserver.org is STILL pointing at the
old-adhoc VM - I had to run it again to make things work. Are you
expecting it to instead point at the `mapserver` container Jeff ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:7>
Keywords: |
old.demo.mapserver.org should still point to old-adhoc VM yes. However
since old-adhoc is now shutdown, the old.demo.mapserver.org alias can be
removed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:8>
Type: task | Status: reopened
Keywords: |
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:9>
Keywords: |
Comment (by strk):
The problem is that ALSO demo.mapserver.org is pointing at old-adhoc
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:10>
Keywords: |
demo.mapserver.org correctly points to the mapserver container; the issue
that you found is that the "old.demo.mapserver.org" alias in nginx still
points to adhoc, where in fact that old alias should now be removed from
nginx settings. Hope this makes sense.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:11>
Keywords: |
no it does not: the new services are live (from the osgeo7 mapserver
container) at demo.mapserver.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:12>
Keywords: |
Regina helped me this the nginx settings, in another ticket. It is all
working great. I am not sure what you see here.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:13>
Keywords: |
Comment (by strk):
For location /geocache nginx is still pointing at old-adhoc
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:14>
Keywords: |
Comment (by strk):
Is that handling of /geocache to be removed ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:15>
Keywords: |
Comment (by strk):
Jeff: as for "what I see here" this is what I see: I can NOT reload nginx
if old-adhoc container is shutdown (as it was). The only way to reload the
configuration (or restart nginx) was to bring old-adhoc back up
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:16>
Keywords: |
Replying to [comment:14 strk]:
There is no more /geocache link, i spent a month of effort to setup
MapCache for this. I documented all of this on the wiki page I mentioned.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:17>
Keywords: |
Replying to [comment:16 strk]:
nginx if old-adhoc container is shutdown (as it was). The only way to
reload the configuration (or restart nginx) was to bring old-adhoc back up
Speaking honestly here, I am not seeing a reason to do that. Everything
is working fine with the new container and demo.mapserver.org services
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:18>
Keywords: |
As documented on the wiki page, the new url for caching is
https://demo.mapserver.org/mapcache/demo/
(the /geocache settings you refer to are not used)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:19>
Keywords: |
Comment (by strk):
Ok so I removed the special handling of demo.mapserver.org/geocache AND
the entry for old.demo.mapserver.org
Only left over nginx configurations pointing at old-adhoc is oam.osgeo.org
-- such service currently points at old-adhoc, does anyone have an idea of
who's in charge of managing it ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2678#comment:20>
